查看: 12218|回复: 54
[下载]PCI Bus demystified (e-books)
发表于 2005-6-10 09:50:18 | 显示全部楼层 |阅读模式
LBSALE[10]LBSALEContents
Introduction ......................................................................... 1
Intended Audience ....................................................................... 2
The Rest of This Book .................................................................. 3
Chapter 1: Introducing the Peripheral Component
Interconnect (PCI) Bus .......................................................... 5
So What is a Computer Bus? ........................................................ 6
Bus Taxonomy............................................................................... 7
What’s Wrong with ISA and Attempts to Fix It ......................... 9
The VESA Local Bus.................................................................. 10
Introducing PCI .......................................................................... 11
Features ....................................................................................... 11
The PCI Special Interest Group ................................................. 12
PCI Signals ................................................................................. 13
Signal Groups ............................................................................. 13
Signal Types ................................................................................ 18
Sideband Signals ......................................................................... 19
Definitions .................................................................................. 20
Summary ..................................................................................... 21
Chapter 2: Arbitration ....................................................... 22
The Arbitration Process ............................................................. 22
An Example of Fairness .............................................................. 25
Bus Parking ................................................................................. 26
Latency........................................................................................ 27
Summary ..................................................................................... 31
Chapter 3: Bus Protocol ..................................................... 32
PCI Bus Commands .................................................................... 32
Basic Read/Write Transactions ................................................... 34
Transaction Termination — Master ........................................... 45
Transaction Termination — Target ............................................ 45
Error Detection and Reporting ................................................... 51
Summary ..................................................................................... 54
Chapter 4: Optional and Advanced Features ..................... 56
Interrupt Handling ..................................................................... 56
The Interrupt Acknowledge Command ..................................... 59
“Special” Cycle ........................................................................... 60
64-bit Extensions ........................................................................ 62
Summary ..................................................................................... 66
Chapter 5: Electrical and Mechanical Issues ..................... 67
A “Green” Architecture ............................................................. 67
Signaling Environments — 3.3V and 5V .................................. 70
5 Volt Signaling Environment.................................................... 72
3.3 Volt Signaling Environment................................................. 77
Timing Specifications ................................................................. 81
66 MHz PCI ................................................................................ 85
Mechanical Details ..................................................................... 88
Summary ..................................................................................... 90
Chapter 6: Plug and Play Configuration ............................ 92
Background ................................................................................. 92
Configuration Address Space ..................................................... 93
Configuration Header — Type 0 ................................................ 95
Base Address Registers (BAR) ................................................. 103
Expansion ROM ....................................................................... 107
Capabilities List ........................................................................ 110
Vital Product Data .................................................................... 111
Summary ................................................................................... 115
Chapter 7: PCI BIOS ......................................................... 116
Operating Modes ...................................................................... 116
Is the BIOS There? ................................................................... 117
BIOS Services ........................................................................... 118
Generate Special Cycle ............................................................ 120
Summary ................................................................................... 124
Chapter 8: PCI Bridging ................................................... 125
Bridge Types .............................................................................. 125
Configuration Address Types.................................................... 128
Configuration Header — Type 1 .............................................. 129
Bus Hierarchy and Bus Number Registers ................................ 130
Address Filtering — the Base and Limit Registers ................... 132
Prefetching and Posting to Improve Performance ................... 135
Interrupt Handling Across a Bridge ......................................... 136
Bridge Support for VGA — Palette “Snooping”...................... 140
Resource Locking ...................................................................... 142
Summary ................................................................................... 146
Chapter 9: CompactPCI .................................................... 148
Why CompactPCI? ................................................................... 148
Mechanical Implementation .................................................... 150
Electrical Implementation ........................................................ 155
CompactPCI Bridging .............................................................. 162
Summary ................................................................................... 165
Chapter 10: Hot Plug and Hot Swap ................................ 166
PCI Hot Plug ............................................................................166
Hot Plug Primitives .................................................................. 170
CompactPCI Hot Swap ............................................................174
Resources for Full Hot Swap ..................................................... 180
Summary ................................................................................... 185
Appendix A: Class Codes ................................................. 187
Appendix B: Connector Pin Assignments ........................ 191
Index ................................................................................. 195
11_735.rar
1.56 MB, 下载次数: 67 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2005-6-18 21:52:18 | 显示全部楼层
Good book!
发表于 2005-6-20 17:16:34 | 显示全部楼层
嗯... 我下了~~
发表于 2005-6-27 23:22:29 | 显示全部楼层
感谢!顶
发表于 2005-6-28 17:35:43 | 显示全部楼层
正是我要的
发表于 2005-6-30 22:45:28 | 显示全部楼层
感谢了,正需要它……
发表于 2005-7-16 13:00:51 | 显示全部楼层
好书啊
发表于 2005-7-19 14:09:33 | 显示全部楼层
hehe!ding
发表于 2005-7-20 10:14:39 | 显示全部楼层
真的有这样好吗
发表于 2005-7-21 21:35:01 | 显示全部楼层
推荐由Mind Share 公司出版的 PCI Speicification解释,非常好!
GMT+8, 2025-12-26 18:13 , Processed in 0.024223 second(s), 9 queries , Gzip On, Redis On.
