楼主: schwang
High PSRR LDO
发表于 2009-6-27 14:02:41 | 显示全部楼层
IEEE 2005 CUSTOM INTEGRATED CIRCUITS CONFERENCE
Abstract - This paper presents a novel two-stage low dropout
regulator (LDO) that minimizes output noise via a pre-regulator
stage and achieves high power supply rejection via a simple
subtractor circuit in the power driver stage. The LDO is
fabricated with a standard 0.35um CMOS process and occupies
0.26mm2 and 0.39mm2 for single and dual output respectively.
Measurement showed PSR is 60dB at 10kHz and integrated noise
is 21.2uVrms ranging from 1kHz to 100kHz.
发表于 2009-6-28 15:49:35 | 显示全部楼层
不错的东西方呀,
发表于 2009-6-28 19:43:34 | 显示全部楼层
Thanks ...
发表于 2009-6-28 20:12:56 | 显示全部楼层
有没有介绍啊?
发表于 2010-2-5 10:16:42 | 显示全部楼层
thank you !
发表于 2010-2-5 14:41:30 | 显示全部楼层
谢谢分享
发表于 2010-2-21 18:42:20 | 显示全部楼层
谢谢,不错
发表于 2010-2-21 22:17:20 | 显示全部楼层
DDDDDDDDDDDDDDDDDDDD
发表于 2010-2-25 11:32:08 | 显示全部楼层
really important in ldo design
发表于 2010-10-19 17:12:23 | 显示全部楼层
谢谢分享 看下
GMT+8, 2025-12-28 20:14 , Processed in 0.449569 second(s), 5 queries , Gzip On, Redis On.
