查看: 50390|回复: 374
免费看Layout for Mixed Analog Digital ICs 要点 [转]
发表于 2008-7-22 12:47:15 | 显示全部楼层 |阅读模式
[size=117%]t[size=117%]
Introduction
Floor plan strategy
Cell layout rules
Layout for reliability
Layout for min X-talk
Layout for matching
Conclusions
[size=117%]•[size=117%]Most of mixed analog/digital chip fails due to the lack of [size=117%]good layout expertise
[size=83%]–[size=83%]matching = f (dimensions, layout)
[size=83%]–[size=83%]cross talk in A/D and D/A
[size=83%]–[size=83%]maximal operation speed limited by wire delay
[size=83%]–[size=83%]reliability (ESD, Latch up)
[size=83%]–[size=83%]EMC/EMI radiation
[size=117%]•[size=117%]A good layout strategy and design is a key to minimal chip [size=117%]area,
minimal layout time and the best performance
[size=133%]•[size=133%]I/O pin placement
AVDD/AVSS,
DVDD/DVSS
AGND/REF
Analog In/Out
Digital In/Out (Minimal crosstalk to Ain/Aout)
Test pins
Xtal In/Out (Close to VDD/VSS)
Bonding rules
[size=133%]•[size=133%]VDD/VSS Routing
Min IR drop (metal wide and length,
vias)
Min ground bounce and on-chip decoupling
Separate AVDD/AVSS and DVDD/DVSS
Structured VDD/VSS routing i.s.o noodle type
Electromigration rules (metal W and contacts)
ESD/Latchup needs separate wide VDD/VSS lines
EMC/EMI issue through VDD/VSS (loop area)
[size=133%]•[size=133%]Differential mode radiation
dt/dt => B(t) loop antenna:
[size=83%]•[size=83%]B(t) [size=83%]µ[size=83%]
I(f) * f
[size=54%]2 [size=83%]* A / r
[size=133%]•[size=133%]Common mode radiation
dv/dt => E(t): wire antenna:
[size=83%]•[size=83%]E(t) [size=83%]µ[size=83%]
I(f) * l * f / r
[size=133%]•[size=133%]Clock Routing
Clock generator (e.g; XTAL) close to AVDD/AVSS
Clock for ASP
[size=83%]•[size=83%]VDD/VSS must be Analog supply
[size=83%]•[size=83%]stable level (without ringing)
[size=83%]•[size=83%]low jitter (phase noise)
Clock for DSP
[size=83%]•[size=83%]driving capability
[size=83%]•[size=83%]min clock skew versus
EMC radiation
[size=83%]•[size=83%]de-phasing with the analog clock for min X-talk
[size=133%]•[size=133%]Cell placement and signal routing
Data path structure
Analog cells v.s. digital cells placement
AGND/VREF must be wide and far from digital
No digital above and near high Z nodes
Sensitive node wire must be short
Critical path (min parasitic RC delay)
Test pads for critical and important nodes
[size=133%]•[size=133%]Basic rules for cell layout
Cell area estimation (W/L, R, C, Routing)
Power supply, In/Out location
Matching requirement (MOST, R, C)
Substrate/well contacts (Latch up)
Do not use Pythagoras rule for spacing
Layout name = Schematic name (data base structure)
[size=83%]•[size=83%]Use unified cell name for all views (hierarchical and reuse)
[size=83%]–[size=83%]Schematic, layout, symbol, functional, description
[size=133%]•[size=133%]ESD layout rules
I/O structures for ESD (HBM, CDM model)
Power supplies protection
Multiple power supplies protection
Separate VDD/VSS Ring connecting to bond pads
Do not use min L devices in the input&output
A small resistor at output (nMOS)
Use only approved I/O cells by expert
[size=133%]•[size=133%]Latchup layout rule
Double guard rings in all I/O structures
[size=83%]•[size=83%]to absorb substrate current
Substrate/Well contacts rules
[size=83%]•[size=83%]to reduce substrate/well resistance
Distance p+ to nWell
Low resistive substrate (Epi-wafer)
[size=133%]•[size=133%]X-talk noise sources
Digital switching noise:
[size=83%]•[size=83%]dv/dt =>capacitive/conductive coupling
[size=83%]•[size=83%]di/dt => inductive/conductive coupling
Analog power output:
[size=83%]•[size=83%]larger di/dt => inductive/conductive coupling
Parasitic poly gate and substrate resistor noise
[size=83%]•[size=83%]ultra low noise amplifiers
[size=133%]•[size=133%]Substrate X-talk (conductive coupling)
L*di/dt at DVSS => ground bounce
Kelvin VSS for substrate contact(Latch up???)
On-chip decoupling techniques
Multi DVDD/DVSS bonding
Local substrate shielding
Fully differential and matched layout
Slew controlled logic design
[size=133%]•[size=133%]Error in CMOS process
Absolute error:
DR/R, DC/C,
DVt/Vt,
Db/b > +-20%
Matching error:
< 0.1% is possible by good circuit
design and layout design
[size=133%]&#8226;[size=133%]Matching => Analog accuracy
Amplifier Gain (R1/R2)
SC filter time constant (C1/C2)
Ratio based A/D and D/A accuracy
Tuning of CT filters (Mosfet-C, Gm-C, Gm-OTA-C)
[size=133%]&#8226;[size=133%]Layout design for matching
Capacitor matching rules
[size=83%]&#8226;[size=83%]design to limit the capacitor ratio value
[size=83%]&#8226;[size=83%]choice of the unit capacitor area with identical layout structure
[size=83%]&#8226;[size=83%]interdigitate layout,
common centroid structure
[size=83%]&#8226;[size=83%]dummy capacitors for uniform environment
Resistor matching rules
[size=83%]&#8226;[size=83%]never use small width W resistor
[size=83%]&#8226;[size=83%]choice of the unit resistor value with L ~ 50---100 um
[size=83%]&#8226;[size=83%]identical layout structure &contacts and the same direction
[size=83%]&#8226;[size=83%]dummy resistors for uniform environment
[size=133%]&#8226;[size=133%]Layout design for matching (Contd)
MOSFET matching rules
[size=83%]&#8226;[size=83%]never use min dimensions (W,L)
[size=83%]&#8226;[size=83%]use the same L for matched MOSFETs
M1&M2
[size=83%]&#8226;[size=83%]define a UNIT MOS such that M2=n*M1
[size=83%]&#8226;[size=83%]the same layout structure for each unit MOS
[size=83%]&#8226;[size=83%]M1&M2 as close as possible and in the same direction
[size=83%]&#8226;[size=83%]cross coupled/common centroid MOS pair
[size=117%]&#8226;[size=117%]For a given design in a given technology,
the layout
[size=117%]determines the final chip performance
[size=83%]–[size=83%]floor plan, noise, matching, cross talk, reliability, EMC etc
[size=117%]&#8226;[size=117%]Good layout strategy leads to minimal chip area,
minimal
[size=117%]layout time and the best performance
[size=117%]&#8226;[size=117%]Expertise in layout design is a basis for a good IC designer
发表于 2008-7-22 12:49:08 | 显示全部楼层
是什么啊?
发表于 2008-7-22 12:50:38 | 显示全部楼层
water
发表于 2008-7-22 12:56:00 | 显示全部楼层
发表于 2008-7-22 12:57:48 | 显示全部楼层
何必呢!
Layout for Mixed Analog Digital ICs t Introduction t Floor plan strategy t Cell layout rules t Layout for reliability t Layout for min X-talk t Layout for matching t Conclusions &#8226;Most of mixed analog/digital chip fails due to the lack of good layout expertise –matching = f (dimensions, layout) –cross talk in A/D and D/A –maximal operation speed limited by wire delay –reliability (ESD, Latch up) –EMC/EMI radiation &#8226;A good layout strategy and design is a key to minimal chip area, minimal layout time and the best performance &#8226;I/O pin placement –AVDD/AVSS, DVDD/DVSS –AGND/REF –Analog In/Out –Digital In/Out (Minimal crosstalk to Ain/Aout) –Test pins –Xtal In/Out (Close to VDD/VSS) –Bonding rules &#8226;VDD/VSS Routing –Min IR drop (metal wide and length, vias) –Min ground bounce and on-chip decoupling –Separate AVDD/AVSS and DVDD/DVSS –Structured VDD/VSS routing i.s.o noodle type –Electromigration rules (metal W and contacts) –ESD/Latchup needs separate wide VDD/VSS lines –EMC/EMI issue through VDD/VSS (loop area) &#8226;Differential mode radiation –dt/dt => B(t) loop antenna: &#8226;B(t) &micro; I(f) * f2 * A / r &#8226;Common mode radiation –dv/dt => E(t): wire antenna: &#8226;E(t) &micro; I(f) * l * f / r &#8226;Clock Routing –Clock generator (e.g; XTAL) close to AVDD/AVSS –Clock for ASP &#8226;VDD/VSS must be Analog supply &#8226;stable level (without ringing) &#8226;low jitter (phase noise) –Clock for DSP &#8226;driving capability &#8226;min clock skew versus EMC radiation &#8226;de-phasing with the analog clock for min X-talk &#8226;Cell placement and signal routing –Data path structure –Analog cells v.s. digital cells placement –AGND/VREF must be wide and far from digital –No digital above and near high Z nodes –Sensitive node wire must be short –Critical path (min parasitic RC delay) –Test pads for critical and important nodes &#8226;Basic rules for cell layout –Cell area estimation (W/L, R, C, Routing) –Power supply, In/Out location –Matching requirement (MOST, R, C) –Substrate/well contacts (Latch up) –Do not use Pythagoras rule for spacing –Layout name = Schematic name (data base structure) &#8226;Use unified cell name for all views (hierarchical and reuse) –Schematic, layout, symbol, functional, description &#8226;ESD layout rules –I/O structures for ESD (HBM, CDM model) –Power supplies protection –Multiple power supplies protection –Separate VDD/VSS Ring connecting to bond pads –Do not use min L devices in the input&output –A small resistor at output (nMOS) –Use only approved I/O cells by expert – &#8226;Latchup layout rule –Double guard rings in all I/O structures &#8226;to absorb substrate current –Substrate/Well contacts rules &#8226;to reduce substrate/well resistance –Distance p+ to nWell –Low resistive substrate (Epi-wafer) – &#8226;X-talk noise sources –Digital switching noise: &#8226;dv/dt =>capacitive/conductive coupling &#8226;di/dt => inductive/conductive coupling –Analog power output: &#8226;larger di/dt => inductive/conductive coupling –Parasitic poly gate and substrate resistor noise &#8226;ultra low noise amplifiers – &#8226;Substrate X-talk (conductive coupling) –L*di/dt at DVSS => ground bounce –Kelvin VSS for substrate contact(Latch up???) –On-chip decoupling techniques –Multi DVDD/DVSS bonding –Local substrate shielding –Fully differential and matched layout –Slew controlled logic design &#8226;Error in CMOS process –Absolute error: DR/R, DC/C, DVt/Vt, Db/b > +-20% –Matching error: < 0.1% is possible by good circuit design and layout design &#8226;Matching => Analog accuracy –Amplifier Gain (R1/R2) –SC filter time constant (C1/C2) –Ratio based A/D and D/A accuracy –Tuning of CT filters (Mosfet-C, Gm-C, Gm-OTA-C) &#8226;Layout design for matching –Capacitor matching rules &#8226;design to limit the capacitor ratio value &#8226;choice of the unit capacitor area with identical layout structure &#8226;interdigitate layout, common centroid structure &#8226;dummy capacitors for uniform environment –Resistor matching rules &#8226;never use small width W resistor &#8226;choice of the unit resistor value with L ~ 50---100 um &#8226;identical layout structure &contacts and the same direction &#8226;dummy resistors for uniform environment &#8226;Layout design for matching (Contd) –MOSFET matching rules &#8226;never use min dimensions (W,L) &#8226;use the same L for matched MOSFETs M1&M2 &#8226;define a UNIT MOS such that M2=n*M1 &#8226;the same layout structure for each unit MOS &#8226;M1&M2 as close as possible and in the same direction &#8226;cross coupled/common centroid MOS pair &#8226;For a given design in a given technology, the layout determines the final chip performance –floor plan, noise, matching, cross talk, reliability, EMC etc &#8226;Good layout strategy leads to minimal chip area, minimal layout time and the best performance &#8226;Expertise in layout design is a basis for a good IC designer
发表于 2008-7-22 12:58:13 | 显示全部楼层
thank you
发表于 2008-7-22 12:59:20 | 显示全部楼层
以上就是内容!content
发表于 2008-7-22 13:32:22 | 显示全部楼层
发表于 2008-7-22 16:29:30 | 显示全部楼层
牛,还要回复.
头像被屏蔽
发表于 2008-7-23 01:18:15 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-11-2 20:45 , Processed in 2.715287 second(s), 5 queries , Gzip On, Redis On.
