楼主: howechee1987
Agilent公司射频设计教程
发表于 2009-7-1 23:26:17 | 显示全部楼层
thanks for sharing
thanks for sharing
发表于 2009-7-11 13:31:13 | 显示全部楼层
Agilent公司射频设计教程
谢谢了
发表于 2009-8-5 19:45:28 | 显示全部楼层
thank you for your share!
发表于 2009-8-5 19:47:12 | 显示全部楼层
thank you
发表于 2009-8-5 19:51:57 | 显示全部楼层
thanks!
发表于 2009-8-5 20:41:24 | 显示全部楼层
酷毙啦
发表于 2009-8-5 21:01:45 | 显示全部楼层
够噢噢噢噢噢噢噢噢噢噢噢噢噢噢的
发表于 2009-8-5 21:13:18 | 显示全部楼层
ddddddddd
发表于 2009-8-5 21:18:45 | 显示全部楼层
复旦大学 2008年在JSSC上发表的 10位 Piplined CMOS ADC论文
A 1.8-V 22-mW 10-bit 30-MS/s Pipelined CMOS ADC for Low-Power Subsampling Applications
Abstract—This paper describes a 10-bit 30-MS/s subsampling
pipelined analog-to-digital converter (ADC) that is implemented
in a 0.18 m CMOS process. The ADC adopts a power efficient
amplifier sharing architecture in which additional switches are introduced
to reduce the crosstalk between the two opamp-sharing
successive stages. A new configuration is used in the first stage
of the ADC to avoid using a dedicated sample-and-hold amplifier
(SHA) circuit at the input and to avoid the matching requirement
between the first multiplying digital-to-analog converter (MDAC)
and flash input signal paths. A symmetrical gate-bootstrapping
switch is used as the bottom-sampling switch in the first stage to
enhance the sampling linearity. The measured differential and integral
nonlinearities of the prototype are less than 0.57 least significant
bit (LSB) and 0.8 LSB, respectively, at full sampling rate. The
ADC exhibits higher than 9.1 effective number of bits (ENOB) for
input frequencies up to 30 MHz, which is the twofold Nyquist rate
(fs/2), at 30 MS/s. The ADC consumes 21.6mWfrom a 1.8-V power
supply and occupies 0.7 mm2, which also includes the bandgap
and buffer amplifiers. The figure-of-merit (FOM) of this ADC is
0.26 pJ/step.
Index Terms—Analog-to-digital converter, opamp sharing,
sample-and-hold, SHA-less, subsampling.
Fudan Pipelined ADC.pdf
1.3 MB, 下载次数: 0 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-8-5 21:22:22 | 显示全部楼层
自己顶一把
GMT+8, 2025-12-31 03:32 , Processed in 0.026134 second(s), 5 queries , Gzip On, Redis On.
