楼主: yanzhe209
亚阈值
发表于 2009-5-25 13:45:39 | 显示全部楼层
谢谢,下来看看
发表于 2009-5-27 21:58:15 | 显示全部楼层
好,谢谢!
发表于 2009-6-6 16:57:42 | 显示全部楼层
对呀,电压低到一定程度,亚阈值问题更严重了!!!
发表于 2009-6-7 05:40:11 | 显示全部楼层
Kan Kan !
发表于 2009-6-12 00:21:20 | 显示全部楼层
you yong xiexie
发表于 2009-7-13 10:19:44 | 显示全部楼层
看看 哈哈哈哈哈哈和
发表于 2009-7-13 14:26:05 | 显示全部楼层
Not really.  One of my projects is to use sub-threshold to increase the performance of a two-stage op amp.  The result is so impressive that I realize it is a very useful technique.  By the way, this technique is also adopted in many industrial applications.
原帖由 lianggu 于 2008-7-27 14:43 发表
If you want to be a professor, you may need this topic. If you want to be in industry, just throw sub-threshold away since no accurate model can support circuit design.
发表于 2009-7-14 10:24:45 | 显示全部楼层
谢谢
下来看看
发表于 2010-4-27 15:15:13 | 显示全部楼层
谢谢,看看
发表于 2010-4-27 20:44:53 | 显示全部楼层
看看~~~~~
GMT+8, 2025-9-14 12:24 , Processed in 0.025418 second(s), 3 queries , Gzip On, Redis On.
