查看: 4216|回复: 12
Basic Precautions for an Analog Designer
发表于 2008-7-9 22:55:48 | 显示全部楼层 |阅读模式
Ajay Kumar
Basic precautions and tips that an Analog Designer should know.
1. Minimum channel length of the transistor should be four to ve times
the minimum feature size of the process. We do it, to make the  of
the transistor low i.e. the rate of change of Id w.r.t to Vds is low.
2. Present art of analog design still uses the transistor in the saturation
region. So one should always keep Vgs of the Transistor 30% above the
Vt.
3. One should always split the big transistor into small transistors having
width or length feature size  15m.
4. W/L Ratio of transistors of the mirror circuit should be less than or
equal to 5, to ensure the proper matching of the transistors in the
layout. Otherwise, it results to the Systamatic O set in the circuit.
5. One should make all the required pins in the schmetic before generating
the layout view. Because it's dicult to add a pin in the layout view.
All IO pins should be a metal2 pins whereas Vdd and Ground should
be metal1 pins.
6. One should rst simulate the circuit with the typical model parameters
of the devices. Since Vt of the trasistor can be anything between
Vt(Typical)  20%. So we check our circuit for the extreme cases i.e.
Vt + 20%, Vt
analog_basic_precau.pdf (77.03 KB , 下载次数: 39 )
头像被屏蔽
发表于 2008-7-10 06:03:27 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-7-10 10:04:03 | 显示全部楼层
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
发表于 2008-7-10 11:19:39 | 显示全部楼层
发表于 2008-7-14 12:47:20 | 显示全部楼层
谢希诶西诶西诶
发表于 2008-7-14 13:04:03 | 显示全部楼层
good share of experience
good thing. thank you. It's a good share of experience.
发表于 2008-7-14 14:50:36 | 显示全部楼层
Where is this from?
发表于 2008-7-19 11:17:28 | 显示全部楼层
thanks
发表于 2010-6-6 20:39:04 | 显示全部楼层
谢谢分享!!!
发表于 2010-6-6 21:41:08 | 显示全部楼层
谢谢分享~好东西
GMT+8, 2025-12-25 13:35 , Processed in 0.021395 second(s), 6 queries , Gzip On, Redis On.
