楼主: squarewood
A 1.5V Current-Mode Operational Amplifier Using Level Shifter Technique
发表于 2009-2-17 09:32:18 | 显示全部楼层
very good
发表于 2009-4-2 11:15:05 | 显示全部楼层
kankan, thanks ........
发表于 2009-4-9 07:11:27 | 显示全部楼层
感激不尽
发表于 2009-8-16 12:06:32 | 显示全部楼层
thanks a lot for sharing this
发表于 2009-8-16 12:09:04 | 显示全部楼层
hao...
发表于 2009-8-16 12:36:17 | 显示全部楼层
thanks
发表于 2009-8-16 12:40:53 | 显示全部楼层
thanks
发表于 2009-8-16 13:00:44 | 显示全部楼层
好东西
发表于 2009-10-13 21:46:20 | 显示全部楼层
Abstract: A low-voltage and low-power consumption of
current-mode operational amplifier designed with level shifter
technique is presented. This simple integrator is built up with
only 9 typical MOSFETs and 2 bias current sources. To
minimize the influence of common-mode signal and noise to
the signal processing, the differential structure is applied. As the
result of simulation, it has been confirmed that the proposed
circuit works as integrator in the frequency range 0-1.6MHz at
1.5V supply voltage and consumed DC power at maximum
8.85gW with 1.2pm double-poly CMOS process.
发表于 2009-10-14 06:11:20 | 显示全部楼层
good...
GMT+8, 2025-12-21 16:10 , Processed in 0.020345 second(s), 4 queries , Gzip On, Redis On.
