查看: 5530|回复: 5
求助(fire&ice)
发表于 2008-6-27 09:44:56 | 显示全部楼层 |阅读模式
当我用enounter在做fire&ice过程中,提取rc时出现如下信息:
Warning: There were 96 unrouted and/or partially routed nets. The first 10 are…
Warning: There were 2 uncomplete nets which have no pins, have disconnencted pins or have more than one partition. They are:
Inst_core/scaer_unit/op_fifo_unit/u0/LITE-LTIELO-NET
-multiple partitions
There is at least one floating resistor from node 68 to node 61 with resistance =10. width =1 and lenth =1
在读入spef文件时出现如下错误
ERRORline 38922*294476. syntax error or can not find in the netlist
Warning: line 49010: D-net inst_core/scaler-unit/filter-green/ not in the netlist
在生成的*.conn文件中
The following nets have unconnected resistance:
我是刚刚开始做数字后端,哪位能告诉我到底是什么问题,怎么解决?
发表于 2008-6-27 10:31:00 | 显示全部楼层
你的tie-low net (tie to ground) 的net routing后,把fire and ice 搞糊涂了。
解决办法:
1,把tie-low net 直接在PR的时候接地。
或者
2,在fire and ice 中告诉工具这是条接地为0的net。
 楼主| 发表于 2008-6-27 11:13:16 | 显示全部楼层
谢谢,我试试
 楼主| 发表于 2008-6-27 14:45:07 | 显示全部楼层
fire & ice
我想问问具体怎么去做,我在floor时的connect global net 中加入tiehi和tielo但还是出现原来的问题
而且我在design browser中看到有两个synopsys_unconnected_0和synopsys_unconnected_1
的net,而这两条net是两个反相器的输出端,而他们的输入端是接在LTIE_LTIEHI_NET和LTIE_LTIELO_NET
第2种方法又是怎么做
谢谢
发表于 2008-6-27 14:58:28 | 显示全部楼层
手上没有fire&Ice,我不记得具体命令了。
最简单办法就是直接替换netlist 中 unconnected_0 为gnd,unconnected_1为vdd。
反正最后你都必须连接,否则就是floating 的wire.
先查查library中是否有tie-low cell.
发表于 2009-12-15 16:48:48 | 显示全部楼层
学习一下!
GMT+8, 2025-12-28 09:51 , Processed in 0.016776 second(s), 6 queries , Gzip On, Redis On.
