查看: 20197|回复: 66
Verilog HDL Quick Reference Guide,IEEE 1364-2001的精华
发表于 2008-6-7 15:56:18 | 显示全部楼层 |阅读模式
不用再看几百页的IEEE 1364-2001了。
Table of Contents
1.0 New Features In Verilog-2001 ..................................................... 1
2.0 Reserved Keywords ...................................................................... 2
3.0 Concurrency ................................................................................. 3
4.0 Lexical Conventions ..................................................................... 3
4.1 Case Sensitivity ................................................................... 3
4.2 White Space Characters ....................................................... 3
4.3 Comments ............................................................................ 3
4.4 Attributes ............................................................................. 3
4.5 Identifiers (names) ............................................................... 4
4.6 Hierarchical Path Names ..................................................... 4
4.7 Hierarchy Scopes and Name Spaces ................................... 4
4.8 Logic Values ........................................................................ 5
4.9 Logic Strengths .................................................................... 5
4.10 Literal Real Numbers .......................................................... 5
4.11 Literal Integer Numbers ...................................................... 6
5.0 Module Definitions ....................................................................... 7
5.1 Module Items ....................................................................... 7
5.2 Port Declarations ................................................................. 8
6.0 Data Type Declarations .............................................................. 10
6.1 Net Data Types .................................................................. 10
6.2 Variable Data Types .......................................................... 12
6.3 Other Data Types ............................................................... 14
6.4 Vector Bit Selects and Part Selects ................................... 15
6.5 Array Selects ..................................................................... 15
6.6 Reading and Writing Arrays .............................................. 15
7.0 Module Instances ........................................................................ 16
8.0 Primitive Instances ..................................................................... 18
9.0 Generate Blocks ......................................................................... 20
10.0 Procedural Blocks ....................................................................... 22
10.1 Procedural Time Controls .................................................. 23
10.2 Sensitivity Lists ................................................................. 23
10.3 Procedural Assignment Statements ................................... 24
10.4 Procedural Programming Statements ................................ 25
11.0 Continuous Assignments ............................................................ 27
12.0 Operators .................................................................................... 28
13.0 Task Definitions ......................................................................... 30
14.0 Function Definitions ................................................................... 31
15.0 Specify Blocks ............................................................................ 32
15.1 Pin-to-pin Path Delays ....................................................... 32
15.2 Path Pulse (Glitch) Detection ............................................ 33
15.3 Timing Constraint Checks ................................................. 34
16.0 User Defined Primitives (UDPs) ................................................ 35
17.0 Common System Tasks and Functions ...................................... 37
18.0 Common Compiler Directives .................................................... 40
19.0 Configurations ............................................................................ 42
20.0 Synthesis Supported Constructs ................................................. 44
verilog_2001_ref_guide.pdf
268.76 KB, 下载次数: 583 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-7 22:24:05 | 显示全部楼层
谢谢楼主!
发表于 2008-7-27 17:21:35 | 显示全部楼层
多谢了
发表于 2008-8-30 19:53:18 | 显示全部楼层
谢谢!
发表于 2009-2-24 10:38:39 | 显示全部楼层
太开心了,终于又有好东西了
发表于 2009-2-24 10:40:53 | 显示全部楼层
顶上,Good Stuff!!!
发表于 2009-3-14 21:33:56 | 显示全部楼层
good
good!!!
发表于 2009-4-15 10:23:32 | 显示全部楼层
谢谢分享
发表于 2009-4-15 10:37:00 | 显示全部楼层
不错,值得一看,再次谢谢楼主分享
发表于 2009-4-16 20:10:07 | 显示全部楼层
好东西!
GMT+8, 2025-12-10 04:03 , Processed in 0.024890 second(s), 10 queries , Gzip On, Redis On.
