查看: 21258|回复: 98
特许半导体hspice model(0.18um)
发表于 2008-6-4 23:36:05 | 显示全部楼层 |阅读模式
CHARTERED SEMICONDUCTOR -----------0.18um Dual Voltage (1.8V/3.3V) Logic Industry Baseline Process. Enjoy!
hspice model.rar
139.5 KB, 下载次数: 517 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-4 23:42:13 | 显示全部楼层
thanks
发表于 2008-6-5 09:54:20 | 显示全部楼层
好东西,哈哈
发表于 2008-6-5 11:08:28 | 显示全部楼层
先看看
先看
发表于 2008-6-5 20:41:45 | 显示全部楼层
xie xie
发表于 2008-6-5 21:38:52 | 显示全部楼层
好东西,谢谢!!!
发表于 2008-6-5 23:21:50 | 显示全部楼层
good for u
发表于 2008-6-6 09:08:15 | 显示全部楼层
CSM 0.18um (1.8V,3.3V, Salicide) Dual-gate Mixed Signal 1P6M
CSM 0.18um (1.8V,3.3V, Salicide) Dual-gate Mixed Signal 1P6M (Apr.06,2006, HSPICE, R-EZ-ER-504).L
* Models included in this release :
*       Model Name      Description
*       nmos_1p8         BSIM3v3   model for thin-gate (1.8V) NMOS transistor
*       pmos_1p8         BSIM3v3   model for thin-gate (1.8V) PMOS transistor
*       nmos_3p3         BSIM3v3   model for thick-gate (3.3V) NMOS transistor
*       pmos_3p3         BSIM3v3   model for thick-gate (3.3V) PMOS transistor
*       nmos_3p3_nat     BSIM3v3   model for thick-gate (3.3V) Native NMOS transistor
*       nmos_1p8_nat     BSIM3v3   model for thin-gate (1.8V) Native NMOS transistor
*       np_1p8           Diode  model for N+/Psub diode  (without DV mask)
*       pn_1p8           Diode  model for P+/Nwell diode (without DV mask)
*       nwp              Diode  model for Nwell/Psub diode
*       np_3p3           Diode  model for N+/Psub diode  (with DV mask)
*       pn_3p3           Diode  model for P+/Nwell diode (with DV mask)
* PW_DNW   Diode  model for P-well/DNW diode
* DNW_Psub  Diode  model for DNW/P-sub diode
*       np_1p8_nat       Diode  model for N+/Psub diode(without DV mask)
*       np_3p3_nat       Diode  model for N+/Psub diode(with DV mask)
*      LPNP_1p8_0P54X0P54 Gummel Poon model for lateral PNP with emitter size of 0.54um x 0.54um
*      LPNP_1p8_0P54X1P2  Gummel Poon model for lateral PNP with emitter size of 0.54um x 1.2um
*      LPNP_1p8_1P2X2P5   Gummel Poon model for lateral PNP with emitter size of 1.2um x 2.5um
*      LPNP_1p8_5X5       Gummel Poon model for lateral PNP with emitter size of 5um x 5um
*      VPNP_0P46X0P46     Gummel Poon model for vertical PNP with emitter size of 0.46um x 0.46um
*      VPNP_0P46X1P2      Gummel Poon model for vertical PNP with emitter size of 0.46um x 1.2um
*      VPNP_1P2X2P5       Gummel Poon model for vertical PNP with emitter size of 1.2um x 2.5um
*      VPNP_5X5           Gummel Poon model for vertical PNP with emitter size of 5um x 5um
*      VPNP_10X10         Gummel Poon model for vertical PNP with emitter size of 10um x 10um
*      VNPN_10X0P42       Gummel Poon model for vertical NPN with emitter size of 10um x 0.42um
*      VNPN_5X0P42        Gummel Poon model for vertical NPN with emitter size of 10um x 0.42um
*      VNPN_10X10         Gummel Poon model for vertical NPN with emitter size of 10um x 10um
*      VNPN_5X5           Gummel Poon model for vertical NPN with emitter size of 5um x 5um
*      VNPN_2X2           Gummel Poon model for vertical NPN with emitter size of 2um x 2um
*       nplus_s         Model for Salicide   N+ diffusion resistor
*       nplus_u         Model for Unsalicide N+ diffusion resistor
*       pplus_s         Model for Salicide   P+ diffusion resistor
*       pplus_u         Model for Unsalicide P+ diffusion resistor
*       npolyf_s        Model for Salicide   N+ poly resistor on field
*       npolyf_u        Model for Unsalicide N+ poly resistor on field
*       ppolyf_s        Model for Salicide   P+ poly resistor on field
*       ppolyf_u        Model for Unsalicide P+ poly resistor on field
*       nwell           Model for Nwell resistor
*       npolyf_u_1k Model for Unsalicide 1K high Rs N+ poly resistor on field
*       rm1             Model for metal1 resistor
*       rm2             Model for metal2 resistor
*       rm3             Model for metal3 resistor
*       rm4             Model for metal4 resistor
*       rm5             Model for metal5 resistor
*       tm9k            Model for top metal 9k resistor
*       mim             Capacitor model for MIM
 楼主| 发表于 2008-6-9 10:36:10 | 显示全部楼层
好东西,大家都来下,全球前5的foundry
发表于 2008-6-9 10:51:12 | 显示全部楼层
是不是不能改文件名和后缀?貌似自己要调用自己
GMT+8, 2025-12-28 10:00 , Processed in 0.021959 second(s), 5 queries , Gzip On, Redis On.
