查看: 15186|回复: 46
问问reset的问题
发表于 2008-6-1 10:18:15 | 显示全部楼层 |阅读模式
在异步设计时需要考虑
reset的recover和removal时间问题,同步reset还用考虑吗?
在异步reset里加入同步器产生“有效沿异步、无效沿同步”怎么理解?无效沿同步了那recover和removal不是都成了0?
我肯定理解有问题,希望dx指正!
发表于 2008-6-1 11:54:09 | 显示全部楼层
有效沿异步、无效沿同步?
出处?
也不理解
 楼主| 发表于 2008-6-1 12:34:24 | 显示全部楼层
应该算是论述复位的经典文档
F__Cbak_技术_异步电~1_SYNORA~1[1].pdf
366.88 KB, 下载次数: 231 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-1 15:04:57 | 显示全部楼层
我们都是用的异步
发表于 2008-6-2 00:18:20 | 显示全部楼层
也再此学学的
发表于 2008-6-2 02:15:06 | 显示全部楼层
So let me try to answer this question
1. For the fully asynchronous resets, reset recovery time violations occur at the deassertion of reset. It is important to note that reset recovery time violations only occur on the deassertion of reset and not the assertion. Therefore, fully asynchronous resets are not recommended.
2. Fully synchronous resets may fail to capture the reset signal itself (failure of assertion) depending on the nature of the clock.For this reason, fully synchronous resets are not recommended unless the capture of the reset signal (reset assertion) can be guaranteed by design. Combining the last two reset types into a hybrid solution that asserts the reset asynchronously and deasserts the reset synchronously would provide the most reliable solution.
3. So the conclusion is, the best solution should be "Asynchronous Assertion, Synchronous Deassertion".
To summarize,
. Reset recovery time violations occur at the deassertion of reset.
. A reset circuit that asserts asynchronously and deasserts synchronously generally provides a more reliable reset than fully synchronous or fully asynchronous resets.
. Different reset types should not be used in a single always block.
. A separate reset synchronizer must be used for each independent clock domain.
if you still have any questions please leave message to me,
发表于 2008-6-2 08:43:25 | 显示全部楼层
我觉得你要表达的意思是,寄存器复位时不需要与时钟沿的同步,但电路功能恢复正常时因该是从时钟有效沿开始
 楼主| 发表于 2008-6-2 10:04:57 | 显示全部楼层
谢谢大家,谢谢6楼的DX,我基本上理解了。我可能犯了个错误,
我原来以为同步复位无效时也要考虑recover和removal时间。现在看应该
是只有异步复位才用考虑这两个时间约束。那片写复位的文档不错,大家可以都
学习学习。
发表于 2008-6-3 19:44:03 | 显示全部楼层
六楼正解。
发表于 2008-6-18 12:41:46 | 显示全部楼层
同步复位,异步撤销
GMT+8, 2025-12-26 07:29 , Processed in 0.028020 second(s), 6 queries , Gzip On, Redis On.
