查看: 45480|回复: 271
大牛Willy Sansen的书:Matching Properties of Deep Sub-Micron MOS Transistors
发表于 2008-5-28 18:54:04 | 显示全部楼层 |阅读模式
Publisher:   Springer
Number Of Pages:   206
Publication Date:   2005-03-24
ISBN-10 / ASIN:   0387243143
ISBN-13 / EAN:   9780387243146
Binding:   Hardcover
Product Description:
Matching Properties of Deep Sub-Micron MOS Transistors examines this interesting phenomenon. Microscopic fluctuations cause stochastic parameter fluctuations that affect the accuracy of the MOSFET. For analog circuits this determines the trade-off between speed, power, accuracy and yield. Furthermore, due to the down-scaling of device dimensions, transistor mismatch has an increasing impact on digital circuits. The matching properties of MOSFETs are studied at several levels of abstraction:
A simple and physics-based model is presented that accurately describes the mismatch in the drain current. The model is illustrated by dimensioning the unit current cell of a current-steering D/A converter.
The most commonly used methods to extract the matching properties of a technology are bench-marked with respect to model accuracy, measurement accuracy and speed, and physical contents of the extracted parameters.
The physical origins of microscopic fluctuations and how they affect MOSFET operation are investigated. This leads to a refinement of the generally applied 1/area law. In addition, the analysis of simple transistor models highlights the physical mechanisms that dominate the fluctuations in the drain current and transconductance.
The impact of process parameters on the matching properties is discussed.
The impact of gate line-edge roughness is investigated, which is considered to be one of the roadblocks to the further down-scaling of the MOS transistor.
 楼主| 发表于 2008-5-28 18:55:47 | 显示全部楼层
Matching Properties of Deep Sub-Micron MOS Transistors by Willy M.C. Sansen
[ 本帖最后由 eBookMania 于 2008-5-28 18:59 编辑 ]
Matching Properties of Deep Sub-Micron MOS Transistors.part1.rar
4.77 MB, 下载次数: 1302
Matching Properties of Deep Sub-Micron MOS Transistors.part2.rar
4.77 MB, 下载次数: 1251
Matching Properties of Deep Sub-Micron MOS Transistors.part3.rar
4.77 MB, 下载次数: 1303
Matching Properties of Deep Sub-Micron MOS Transistors.part4.rar
468.35 KB, 下载次数: 1089
发表于 2008-5-28 19:25:20 | 显示全部楼层
thanks
发表于 2008-5-29 02:13:13 | 显示全部楼层
路过算了
发表于 2008-5-29 16:26:51 | 显示全部楼层
楼主的好东东蛮多的,
支持一下
发表于 2008-5-29 18:02:17 | 显示全部楼层
是扫描版的?
发表于 2008-5-29 18:24:07 | 显示全部楼层
what a good book!thanks!
发表于 2008-5-29 18:57:54 | 显示全部楼层
发表于 2008-5-29 19:00:33 | 显示全部楼层
我不知道讲什么的哈
发表于 2008-5-29 19:04:31 | 显示全部楼层
下了看下
GMT+8, 2025-12-22 00:41 , Processed in 0.031512 second(s), 7 queries , Gzip On, Redis On.
