在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2274|回复: 6
IEEE paper about Optimization of Dead Times in DC–DC Conveters
发表于 2008-5-28 18:21:56 | 显示全部楼层 |阅读模式
Title
Sensorless Optimization of Dead Times in DC–DC Converters With Synchronous Rectifiers
Abstract—This paper introduces an approach to achieve optimum
dead times in dc–dc converters with synchronous rectifiers
without sensing any of the power-stage signals other than the
output voltage. The dead times are adjusted adaptively to minimize
the duty-cycle command, which results in maximization of
the converter efficiency. The method is particularly well suited for
digital controller implementation, requiring no additional analog
components or modifications of standard gate-drive circuitry.
Experimental results for a digitally controlled 5 V-to-1 V, 5-A synchronous
buck converter demonstrate practical implementation
of the sensorless dead-time optimization algorithm.
Index Terms—DC–DC converter, dead time, synchronous rectifier,
sensorless.
01650300.pdf
845.84 KB, 下载次数: 88 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-5-28 22:06:57 | 显示全部楼层
thanks
发表于 2008-5-28 23:00:18 | 显示全部楼层
thank you very much
发表于 2009-4-10 00:39:17 | 显示全部楼层
thanks
发表于 2011-1-16 11:47:33 | 显示全部楼层
ddddddddddddddd
发表于 2011-1-16 12:50:15 | 显示全部楼层
dddddddddddddddddddddddddd
发表于 2011-5-6 17:33:34 | 显示全部楼层
thanks
GMT+8, 2024-12-26 02:19 , Processed in 0.020119 second(s), 7 queries , Gzip On, Redis On.
