查看: 22331|回复: 73
MOS器件模型参数提取
发表于 2008-5-26 14:35:51 | 显示全部楼层 |阅读模式
Abstract
Smart power integrated circuits (SPICs), which will cause the second technology
revolution, are used more and more widely. The application fields include switching
power supply, electronic ballast, motor drive, mobile electronic, display drive, etc.. In
this paper, the SPIC mentioned here is used to the electronic ballast.
Firstly, the research and development on SPICs are reviewed briefly, form which
we get the aim of this design: the power integrated circuit comprises not only power
devices, but also logic controlled devices.
Secondly, according to the process which is used in this SPIC, the method of
parameter extraction of low-voltage MOSFET is presented, with the help of device
simulation and software AURORA. The extracted model parameters are used in the
SPIC design, and would act as a reference after the process test parameters were get.
Then, a power MOSFET model and the parameter extraction method for it are
introduced, both of them are presented by Prof. Chen. Based on the method, the way
to measure the resistance and the capacitance, both of which vary with the applied
voltage, is discussed. And then it is provided that how to include the
voltage-dependent resistance and capacitance into the device model library for
schematic simulation.
In appendix, several examples of shell program associated with software MEDICI
in UNIX operation system are introduced. Device simulation and data processing may
be more efficient with the help of shell program.
MOS器件模型参数提取.rar
1.54 MB, 下载次数: 1697 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-5-27 00:15:02 | 显示全部楼层
GOOOOOOOOOOOOOOOOOD
发表于 2008-5-27 09:48:29 | 显示全部楼层
这方面的资源比较多,我就多发些过来。
发表于 2008-5-27 19:28:15 | 显示全部楼层
发表于 2008-5-28 00:44:10 | 显示全部楼层
有下有推喔
发表于 2008-5-28 19:47:51 | 显示全部楼层
赞!感谢楼主!
发表于 2008-5-29 01:41:16 | 显示全部楼层
收留备用
 楼主| 发表于 2008-6-6 09:22:33 | 显示全部楼层
其实这些文章是大学同学的硕士论文,我个人有这种资源,就提供给大家参考。有的教育网也是可以下载下来的。
发表于 2008-6-10 00:05:31 | 显示全部楼层
好东西啊!
发表于 2008-6-10 10:34:02 | 显示全部楼层
很好的資料,感謝大大無私的分享。
GMT+8, 2025-12-24 08:15 , Processed in 0.029294 second(s), 6 queries , Gzip On, Redis On.
