查看: 1904|回复: 0
编译出错 请高手进来看看
发表于 2008-5-26 13:46:37 | 显示全部楼层 |阅读模式
Show88(unsigned char hang,unsigned char lie,unsigned int address)
unsigned char i;
if(lie>16) {return ;}
   if(lie<8) //如果列数<8(0,1,2,3,4,5,6,7)则写在第一屏上
       {SetLine(hang);
        SetColumn(lie<<3);
           for(i=0;i<8;i++)
            WriteByte1(HZTable[address+i][32]);
    else {lie=lie & 0x07; //防止越界
           SetLine(hang);
               SetColumn(lie<<3);
                  for(i=0;i<8;i++)
                         WriteByte2(HZTable[address+i][32]);
    //否则 (8,9,10,11,12,13,14,15)写在第二屏上
void ShowHZ(unsigned char low,unsigned char column1,unsigned int hzcode)
    low=low<<1; //lin*2
    Show88(low,column1,HZTable[hzcode]);//在这里报错:implicit cast of pointer to "int"
   Show88(low,column1+1,HZTable[hzcode]+8);//在这里报错:implicit caster pointer to "int"
   Show88(low+1,column1,HZTable[hzcode]+16);//在这里报错:implicit caster pointer to "int"
   Show88(low+1,column1+1,HZTable[hzcode]+24);//在这里报错:implicit caster pointer to "int"
编译有四个错误 都注在程序里了 不知道该如何处理这种类型的错误 希望高手帮帮忙:)
GMT+8, 2025-12-20 20:13 , Processed in 0.017981 second(s), 6 queries , Gzip On, Redis On.
