楼主: frzhang1
Noise Reduction Techniques in Electronic Systems, 2nd Edition(文件小且略清晰)
发表于 2009-10-5 18:52:27 | 显示全部楼层
谢谢楼主的分享
发表于 2009-10-17 15:52:31 | 显示全部楼层
好書,十分感謝
发表于 2009-10-17 16:25:57 | 显示全部楼层
hao!!!
发表于 2009-10-27 09:21:09 | 显示全部楼层
下载完毕,非常感谢!!!
发表于 2009-11-14 23:58:23 | 显示全部楼层
10# chen_zhenfeng
There is a specific topic in this book that I have not seem covered inany of the 25+ book that I have on electromagnetic phenomena. The topicis the shield cut-off frequency of a coaxial cable. Common-modecurrents at low frequencies (below a few hundred hertz) cause noiseproblems with coaxial cables, but signals above tens of kilohertz donot. This is vital data which is apparently not explained in many textbooks. For me, this topic justifies the cost of the text. Having saidthat, I am annoyed because the book is quite expensive relative toother books of its size and age. The point is that you have to buy it,but it is expensive to do so.
发表于 2009-11-15 00:03:16 | 显示全部楼层
确实是好书,kankan
发表于 2009-11-15 00:03:24 | 显示全部楼层
187# revolution1983
Even an advanced designer will benefit from this book, although you,like me, won't necessarily want to read all of it. It is sufficient topick and choose areas of particular interest. The less advanceddesigner would clearly benefit more and the book would thereforerepresent better value for them. Given a choice between this one andMorrison's Grounding and Shielding Techniques in Instrumentation, pickthis one. This one is more technically accurate and useful.
发表于 2009-11-15 00:13:36 | 显示全部楼层
189# revolution1983
Henry Ott provides an excellent reference in "Noise ReductionTechniques in Electronic Systems". It is a comprehensive look at thesources of EMI in electronic circuits and also provides valuableinsights into the reduction/elimination of the noise interference tomeet the applicable test standards. It is must-read for noviceengineers and a great refresher for the more experienced designer. NoEMC engineer or system design engineer worth his/her salt should bemissing this volume on their bookshelf!
发表于 2009-11-19 17:49:09 | 显示全部楼层
我要下啊
发表于 2009-11-19 17:51:14 | 显示全部楼层
好书,推荐
GMT+8, 2025-12-27 14:46 , Processed in 0.018413 second(s), 4 queries , Gzip On, Redis On.
