楼主: xyzll32
请教IC610的安装问题?
发表于 2011-4-27 21:44:58 | 显示全部楼层
我的貌似也有这个问题呢
发表于 2011-5-11 15:42:25 | 显示全部楼层
root@liliang:~# sudo gedit /home20:33:38 (lmgrd) The TCP port number in the license, 5280, is already in use.
哪位高手指导一下?
change the TCP number inside license file from 5280 to something else, like 5282 or 7280
TCP number 5280 is used by other program
之前的问题是这样的
参考下面的博客安装的,不过那个笔者是在suse10下装的
http://www.edacn.net/index.php/112944/viewspace-31791.html
我现在用的是ubuntu7.10 按照上面的网站安装以及设置后。
在终端中运行   lmli
却显示下面的错误
18:31:17 (lmgrd) Can't make directory /usr/tmp/.flexlm, errno: 2(No such file or directory)
18:31:17 (lmgrd) Can't open /usr/tmp/.flexlm/lmgrdl.31958, errno: 2
make sure you have /usr/tmp directory and is writable by "world". (directory protection is drwxrwxrwx)
下面是我设置的环境变量
alias lmli='/home/eda/ic610/tools/bin/lmgrd -c /home/eda/ic610/share/license/license.dat'
export OA_HOME=/home/eda/ic610/OA
export CDS_ROOT=/home/eda/ic610
export CDS_LIC_FILE=5280@liliang
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export CDS_Netlisting_Mode=Analog
export PATH=($CDS_ROOT/tools/bin $CDS_ROOT/tools/dfII/bin $PATH)
export MOZILLA_HOME=/usr/bin/netscape
set up is correct. try to re-start the lmgrd program. make sure old lmgrd is "killed"
发表于 2011-5-11 15:46:06 | 显示全部楼层
哪位高手指导一下?
之前的问题是这样的
在终端中运行   lmli
却显示下面的错误
下面是我设置的环境变量
use "pmacpmac"'s recommendation or
lmdown -c license-file
to shut down old daemon
发表于 2011-5-29 18:22:27 | 显示全部楼层
我也遇到了。。怎么搞啊???????????????????????????????????????????
发表于 2014-4-8 17:56:40 | 显示全部楼层
怎么解决的lz?求助?
GMT+8, 2025-10-1 10:33 , Processed in 0.013174 second(s), 3 queries , Gzip On, Redis On.
