查看: 3030|回复: 10
High-Speed, Low-Power A/D Converter for a Low-Cost UWB
发表于 2008-5-12 22:08:02 | 显示全部楼层 |阅读模式
Sub-sampling Radio mchenphd.pdf (1.91 MB , 下载次数: 95 )
 楼主| 发表于 2008-5-12 22:44:29 | 显示全部楼层
berkeley de phd paper.
发表于 2008-5-13 02:45:57 | 显示全部楼层
好东西学习
发表于 2008-5-13 08:47:27 | 显示全部楼层
have a look
发表于 2008-5-13 20:40:56 | 显示全部楼层
 楼主| 发表于 2008-5-16 12:57:46 | 显示全部楼层
tingyouyongde.
发表于 2008-6-26 16:20:31 | 显示全部楼层
thanks
thanks
发表于 2008-6-26 16:22:21 | 显示全部楼层
thanks
发表于 2008-7-12 17:16:11 | 显示全部楼层
采用的是逐次逼近的,不是flash ADC.
The sample rate of 600-MS/sec was achieved by time interleaving two single ADCs, which were fabricated in a 0.13-um standard digital CMOS process. The ADC achieves a peak SNDR of 34 dB, while only consuming
an active area of 0.12 mm2 and power consumption of 5.3 mW.
发表于 2008-10-16 20:32:54 | 显示全部楼层
谢谢。
GMT+8, 2025-12-29 20:43 , Processed in 0.021571 second(s), 5 queries , Gzip On, Redis On.
