查看: 2268|回复: 5
Hspice 牛人请进!!!
发表于 2008-5-3 15:37:27 | 显示全部楼层 |阅读模式
在Hspice模拟时,
.opt
.option
.options
三者区别是什么????????????????
发表于 2010-12-24 16:14:24 | 显示全部楼层
I also ask!
发表于 2010-12-24 16:28:50 | 显示全部楼层
.param
.parameter
.parameters
发表于 2010-12-24 17:29:31 | 显示全部楼层
Full name of the command card: .options
".opt" and ".option" give the same effect as mentioned above, and are both acceptable by the (syntax) pre-processor of Hspice.
".parameter" and ".parameters" are not accepted by the syntax checker.
Only ".param" is OK.
发表于 2010-12-24 18:50:48 | 显示全部楼层
帮你顶顶!!
发表于 2010-12-24 18:52:30 | 显示全部楼层
不错的软件哦!!!
GMT+8, 2025-12-29 18:39 , Processed in 0.015139 second(s), 4 queries , Gzip On, Redis On.
