楼主: supergold
A 75 W rail-to-rail class AB CMOS operational amplifier
头像被屏蔽
发表于 2009-3-31 16:32:40 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-6-11 23:07:09 | 显示全部楼层
should be 75uw?????
发表于 2009-7-7 23:17:11 | 显示全部楼层
This paper presents the design and the realization of single-ended-to-fully dierential and fully dierential-
to-single-ended ampliers to be used in an audio signal processing system. The proposed blocks
allow to reduce signicantly the pin number of the developed system, while guaranteeing the high
quality (16 bit) performance required in an audio channel. The proposed circuits have been realized
in a standard 3:3V 0:35 m CMOS technology and achieve a Dynamic Range in excess of 90 dB
with a Total Harmonic Distortion lower than −80 dB for a full scale signal amplitude. Their power
consumption (≈6mW and each) and the area (0:1mm2 each) are nally negligible with respect to the
other blocks in the overall systems. Copyright ? 2003 John Wiley & Sons, Ltd.
发表于 2009-7-13 21:59:42 | 显示全部楼层
看看,谢谢了
发表于 2009-8-4 13:55:04 | 显示全部楼层
谢谢楼主!!!
发表于 2009-8-4 15:14:18 | 显示全部楼层
LZ太不讲究了
很小的功率 75mW
发表于 2009-8-6 17:09:14 | 显示全部楼层
谢谢分享
Thanks for sharing
发表于 2009-8-6 17:13:48 | 显示全部楼层
我怎么看不到?
谢谢, 看看这个东西
发表于 2009-8-15 15:53:56 | 显示全部楼层
jfkdsaghe
发表于 2009-8-19 23:43:32 | 显示全部楼层
应该是75mw
GMT+8, 2025-12-28 23:55 , Processed in 0.018052 second(s), 4 queries , Gzip On, Redis On.
