查看: 3074|回复: 6
求助VHDL程序(急)
发表于 2008-4-27 09:17:27 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
library synplify;
use synplify.attributes.all;
entity blockdram is
generic(
depth: integer;
Dwidth: integer;
Awidth: integer
port(
addra: IN std_logic_VECTOR(Awidth-1 downto 0);
clka: IN std_logic;
addrb: IN std_logic_VECTOR(Awidth-1 downto 0);
clkb: IN std_logic;
dia: IN std_logic_VECTOR(Dwidth-1 downto 0);
wea: IN std_logic;
dob: OUT std_logic_VECTOR(Dwidth-1 downto 0));
end blockdram;
architecture arch_blockdram of blockdram is
type ram_memtype is array (depth-1 downto 0) of std_logic_vector
signal mem : ram_memtype := (others => (others => '0'));
attribute syn_ramstyle of mem : signal is "block_ram";
signal addrb_reg: std_logic_vector(Awidth-1 downto 0);
begin
wr: process( clka )
begin
  if rising_edge(clka) then
   if wea = '1' then
    mem(conv_integer(addra)) <= dia;
   end if;
  end if;
end process wr;
rd: process( clkb )
begin
  if rising_edge(clkb) then
   addrb_reg <= addrb;
  end if;
    end process rd;
dob <= mem(conv_integer(addrb_reg));
end arch_blockdram;
红色字体出现错误,请问是什么原因,我用的是Modelsim
发表于 2008-4-27 20:19:13 | 显示全部楼层
报错的信息是怎么说的?看样子是你的library它找不到啊.
发表于 2008-4-28 09:00:33 | 显示全部楼层
你没有加入syniplify的库,当然要报错了!
发表于 2008-4-28 09:37:16 | 显示全部楼层
找不到这个库
 楼主| 发表于 2008-4-29 12:36:23 | 显示全部楼层
syniplify的库怎么加的啊,高手指点下,谢谢
发表于 2008-4-29 20:37:54 | 显示全部楼层
这个问题很简单,我只是奇怪,这段代码是RAM仿真模型,为什么要调用Synplify的库?
Synplify只是综合工具,不应该和仿真库有交集啊?
发表于 2008-6-14 16:05:40 | 显示全部楼层
进来看看
进来看看;;
GMT+8, 2025-10-31 19:50 , Processed in 0.023548 second(s), 6 queries , Gzip On, Redis On.
