查看: 9192|回复: 31
Optimum Feedback Amplifier Design for control system
发表于 2008-4-15 01:11:23 | 显示全部楼层 |阅读模式
For Control Systems
Abstract:
Many designers think of control system feedback loop compensation only in
terms of stable or unstable. In reality, there is an optimum error amplifier
transfer function for any given loop crossover frequency and phase margin.
The optimum design is shown to be the one with the highest gain below
crossover and the lowest gain above crossover. There is a unique pole-zero
placement to achieve optimum performance. This pole-zero placement and
resultant circuit component values can be determined without trail-and-error.
In addition, there is an optimum open loop crossover frequency (loop
bandwidth) or any given phase margin.
Optimum Feedback Amplifier Design For Control Systems.pdf
1.84 MB, 下载次数: 138 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-4-16 00:45:34 | 显示全部楼层
好的好的
发表于 2008-4-16 02:22:36 | 显示全部楼层
谢谢楼主,google了一下,找到免费下载的
http://hep.uchicago.edu/atlas/docs/lvpsdocs/Reference%20Material/tp-03.pdf
发表于 2008-4-16 09:48:38 | 显示全部楼层
qqqqqqqqqqqqqqqqqqqqqqqqq
 楼主| 发表于 2008-4-17 15:28:08 | 显示全部楼层
goooooooooooooooooooooooooooooood
发表于 2008-4-17 16:04:11 | 显示全部楼层
:victory:
发表于 2008-4-17 18:15:16 | 显示全部楼层
upupupup
发表于 2008-4-17 18:16:14 | 显示全部楼层
有免费的
发表于 2008-4-17 18:18:49 | 显示全部楼层
haode.xiexie
发表于 2008-4-17 19:22:25 | 显示全部楼层
thanks!
GMT+8, 2025-12-29 03:25 , Processed in 0.026682 second(s), 8 queries , Gzip On, Redis On.
