查看: 5575|回复: 17
[总有人需要]]低压CMOS运放设计IEEE论文
发表于 2008-4-2 23:32:06 | 显示全部楼层 |阅读模式
A New Implementation of Constant-g, OpAmp Input Stage for CMOS Low
Voltage Applications
In this paper we propose a new implementation method for the
design of OpAmp input stage with rail-to-rail constant-g,. The
new implementation is based on processing signal currents rather
than handling DC tail currents. As a result, it is universal in that
the constant-g, can be obtained independent of input transistortypes
(MOS or Bipolar) and their operating regions (weak or
strong inversion for MOS and active for Bipolar).
To demonstrate the idea, a new MOS-type input stage has been
designed with 2-pm CMOS process and simulation results of input
stage transconductance are provided. The common mode
input voltage can even exceed the positive and the negative rails
by 300mV.
 楼主| 发表于 2008-4-2 23:32:59 | 显示全部楼层
lp opamp~
低压CMOS运放设计IEEE论文.rar
304.26 KB, 下载次数: 178 , 下载积分: 资产 -2 信元, 下载支出 2 信元
lp opamp
头像被屏蔽
发表于 2008-4-3 19:01:11 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2008-4-3 23:14:22 | 显示全部楼层
楼上的是发帖狂人,识货的下~~
发表于 2008-12-30 14:32:05 | 显示全部楼层
goooood
发表于 2009-10-19 11:41:44 | 显示全部楼层
基础的东西~要好好学习啊
发表于 2009-10-19 13:00:12 | 显示全部楼层
thanks!!!
 楼主| 发表于 2010-10-20 11:08:38 | 显示全部楼层
自己顶~~
发表于 2011-7-22 23:42:36 | 显示全部楼层
回复 2# matlab11
    haodongxi
发表于 2011-12-14 13:40:53 | 显示全部楼层
good
GMT+8, 2025-12-30 03:44 , Processed in 0.025077 second(s), 8 queries , Gzip On, Redis On.
