查看: 32578|回复: 139
可综合verilog语法下载
发表于 2008-3-22 13:38:23 | 显示全部楼层 |阅读模式
Synthesizable Verilog is a subset of the full Verilog HDL [9] that lies within
the domain of current synthesis tools (both RTL and behavioral).
This document speci es a subset of Verilog called V0.1 This subset is intended
as a vehicle for the rapid prototyping of ideas.
The method chosen for developing a semantics of all of synthesizable Verilog
is to start with something too simple { V0 { and then only to make it more
complicated when the simple semantics breaks. This way it is hoped to avoid
unnecessary complexity. It is planned to de ne sequence of bigger and bigger
subsets (V1, V2 etc.) that will converge to the version of Verilog used in the
VFE project2 at Cambridge.
Di erent tools interpret Verilog di erently: industry standard simulators like
Cadence's Verilog XL are based on the scheduling of events. Synthesizers and
cycle-simulators are based on a less detailed clocked register transfer level
(RTL) semantics.
It is necessary to give an explicit semantics to Verilog to provide a basis for
de ning what it means to check the equivalence between behavioral proto-
types and synthesized logic.。。。。。
可综合verilog.rar
292.49 KB, 下载次数: 576 , 下载积分: 资产 -2 信元, 下载支出 2 信元
可综合verilog语法的详细分析,剑桥大学
发表于 2008-3-25 22:47:26 | 显示全部楼层
好东西,先顶一个
发表于 2008-4-5 11:50:36 | 显示全部楼层
以前下过,唉
发表于 2008-4-5 11:52:03 | 显示全部楼层
资料太多,总是下重复的,
发表于 2008-4-6 21:55:03 | 显示全部楼层
Thanks for that!
发表于 2008-4-17 03:22:40 | 显示全部楼层
Thanks for Sharing
发表于 2008-4-17 10:07:05 | 显示全部楼层
qqqqqqq
发表于 2008-4-17 10:08:11 | 显示全部楼层
already have
发表于 2008-4-19 16:52:22 | 显示全部楼层
好东西就是要顶
发表于 2008-5-4 08:28:33 | 显示全部楼层
感覺挺不錯的東西
感謝分享囉
可以綜合verilog語法
GMT+8, 2025-12-28 11:15 , Processed in 0.024371 second(s), 8 queries , Gzip On, Redis On.
