查看: 32390|回复: 168
发4本关于noise的书。
发表于 2008-3-20 18:26:54 | 显示全部楼层 |阅读模式
Signal Processing Noise
introduction:http://www.amazon.com/Signal-Pro ... plied/dp/0849310253
Book Description:
Additive and multiplicative noise in the information signal can significantly limit the potential of complex signal processing systems, especially when those systems use signals with complex phase structure. During the last few years this problem has been the focus of much research, and its solution could lead to profound improvements in applications of complex signals and coherent signal processing. Signal Processing Noise sets forth a generalized approach to signal processing in multiplicative and additive noise that represents a remarkable advance in signal processing and detection theory. This approach extends the boundaries of the noise immunity set by classical and modern signal processing theories, and systems constructed on this basis achieve better detection performance than that of systems currently in use. Featuring the results of the author's own research, the book is filled with examples and applications, and each chapter contains an analysis of recent observations obtained by computer modelling and experiments. Tables and illustrations clearly show the superiority of the generalized approach over both classical and modern approaches to signal processing noise. Addressing a fundamental problem in complex signal processing systems, this book offers not only theoretical development, but practical recommendations for raising noise immunity in a wide range of applications.
[ 本帖最后由 lxandlj 于 2008-3-20 18:35 编辑 ]
Signal Processing Noise.part1.rar
3.81 MB, 下载次数: 1063 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Signal Processing Noise.part2.rar
329.96 KB, 下载次数: 324 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-3-20 18:44:04 | 显示全部楼层
Noise in High-Frequency Circuits and Oscillators
Description:
A classroom-tested book addressing key issues of electrical noise
This book examines noise phenomena in linear and nonlinear high-frequency circuits from both qualitative and quantitative perspectives. The authors explore important noise mechanisms using equivalent sources and analytical and numerical methods. Readers learn how to manage electrical noise to improve the sensitivity and resolution of communication, navigation, measurement, and other electronic systems.
Noise in High-Frequency Circuits and Oscillators has its origins in a university course taught by the authors. As a result, it is thoroughly classroom-tested and carefully structured to facilitate learning. Readers are given a solid foundation in the basics that allows them to proceed to more advanced and sophisticated themes such as computer-aided noise simulation of high-frequency circuits.
Following a discussion of mathematical and system-oriented fundamentals, the book covers:
* Noise of linear one- and two-ports
* Measurement of noise parameters
* Noise of diodes and transistors
* Parametric circuits
* Noise in nonlinear circuits
* Noise in oscillators
* Quantization noise
Each chapter contains a set of numerical and analytical problems that enable readers to apply their newfound knowledge to real-world problems. Solutions are provided in the appendices.
With their many years of classroom experience, the authors have designed a book that is ideal for graduate students in engineering and physics. It also addresses key issues and points to solutions for engineers working in the burgeoning satellite and wireless communications industries.
Table of content:
Preface.
  Mathematical and System-oriented Fundamentals.
 .1 Introduction.
 .2 hlathematical basics for the description of noise signals.
 .3 Transfer of noise signals by linear networks.
  Noise of Linear One- and Two-Ports.
 .1 Noise of one-ports.
 .2 Noise of two-ports.
 .3 Noise figure of linear two-ports.
  Measurement of Noise Parameters.
 .1 Measurement of noise power.
 .2 Measurement of the correlation function and the crossspectrum.
 .3 Illustrative interpretation of the correlation.
 .4 Measurement of the equivalent noise temperature of a one-port.
 .5 Special radiometer circuits.
 .6 Measurement of the noise figure.
 .7 Measurement of minimum noise figure and optimum source impedance.
 .8 De-embedding of the noise parameters.
 .9 Alternative determination of the noise temperature of a one-port.
  Noise of Diodes and Transistors.
 .1 Shot noise.
 .2 Shot noise of Schottky diodes.
 .3 Shot noise of pn-diodes.
 .4 Noise of PIK diodes.
 .5 Noise equivalent circuits of bipolar transistors.
 .6 Noise of field effect transistors.
  Parametric Circuits.
 .1 Parametric theory.
 .2 Down converters with Schottky diodes.
 .3 Mixer circuits.
 .4 Noise equivalent circuit of pumped Schottky diodes.
 .5 Noise figure of down-converters with Schottky diodes.
 .6 Mixers with field effect transistors.
 .7 Noise figure of down converters with field effect transistors.
 .8 Harmonic mixers.
 .9 Noise figure of harmonic mixers.
 .10 Noise figure measurements of down converters.
 .11 Noise figure of a parametric amplifier.
 .12 Up-converters with varactors.
  Noise in Non-linear Circuits.
 .1 Introduction.
 .2 Problems with the noise characterization of non-linear two-ports.
 .3 l/f-noise.
 .4 Amplitude and phase noise.
 .5 Normalized single sideband noise power density.
 .6 Amplitude and phase noise of amplifiers.
 .7 Transformation of amplitude and phase noise in linear two-ports.
 .8 Amplitude and phase noise in non-linear two-ports.
 .9 Measurement of the phase noise.
  Noise in Oscillators.
 .1 Two-port and one-port oscillators.
 .2 Oscillation condition.
 .3 Noise analysis.
 .4 Stability condition.
 .5 Examples.
 .5.1 Two-port oscillator with transmission resonator.
 .5.2 One-port oscillator with a series resonator.
 .5.3 Voltage controlled oscillator (VCO).
 .6 Noise in phase-locked loop circuits.
 .7 Measurement of the oscillator noise.
 .7.1 Amplitude noise.
 .7.2 Phase noise.
 .7.3 Injection locking.
 .8 Disturbing effects of oscillator noise.
 .8.1 Heterodyne reception.
 .8.2 Sensitivity of a spectrum analyzer.
 .8.3 Distance measurements.
 .8.4 Velocity measurements.
 .8.5 Transmission of information by a frequency or.
 hase modulated carrier signal.
 .8.6 Measurement system for the microwave gas spectroscopy.
  Quantization Noise.
 .1 Quantization noise of analog-to-digital converters.
 .2 Quantization noise of fractional divider phase locked loops.
 .2.1 Application of the Sigma-Delta modulation.
 .2.2 Multiple integration.
 .2.3 Identity of the cascade and the chain circuit.
 .2.4 Chain circuit with weighting coefficients.
 .2.5 Transient behavior of a fractional logic circuit.
 .2.6 Fractional divider without a PLL.
 ppendix A Solutions to the problems of Chapter 1.
 ppendix B Solutions to the Problems of Chapter 2.
 ppendix C Solutions to the Problems of Chapter 3.
 ppendix D Solutions to the Problems of Chapter 4.
 ppendix E Solutions to the Problems of Chapter 5.
 ppendix F Solutions to the Problems of Chapter 6.
 ppendix G Solutions to the Problems of Chapter 7.
 ppendix H Solutions to the Problems of Chapter 8.
 eferences.
Index.
[ 本帖最后由 lxandlj 于 2008-3-20 18:46 编辑 ]
Noise in High-Frequency Circuits and Oscillators.part1.rar
3.81 MB, 下载次数: 471 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Noise in High-Frequency Circuits and Oscillators.part2.rar
3.81 MB, 下载次数: 690 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-3-20 18:45:12 | 显示全部楼层
TDDDDDDDDD
 楼主| 发表于 2008-3-20 18:50:05 | 显示全部楼层
Noise in High-Frequency Circuits and Oscillators的第3,4部分
Noise in High-Frequency Circuits and Oscillators.part3.rar
3.81 MB, 下载次数: 971 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Noise in High-Frequency Circuits and Oscillators.part4.rar
2.36 MB, 下载次数: 541 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-3-20 18:58:39 | 显示全部楼层
第三本:Acoustic Echo and Noise Control A Practical Approach
Acoustic Echo and Noise Control: A Practical Approach
ISBN: 978-0-471-45346-8
Hardcover
444 pages
May 2004, Wiley-IEEE Press
Review:
 This book cannot be praised enough...a must have reference for digital signal processing designers…as a golden mine for projects…" (Computing Reviews.com, March 7, 2005)
Book Description:
Authors are well known and highly recognized by the "acoustic echo and noise community."
Presents a detailed description of practical methods to control echo and noise
Develops a statistical theory for optimal control parameters and presents practical estimation and approximation methods
共5个part
[ 本帖最后由 lxandlj 于 2008-3-20 19:00 编辑 ]
Acoustic Echo and Noise Control A Practical Approach.part1.rar
3.81 MB, 下载次数: 354 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Acoustic Echo and Noise Control A Practical Approach.part2.rar
3.81 MB, 下载次数: 250 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-3-20 19:04:07 | 显示全部楼层
3,4part
Acoustic Echo and Noise Control A Practical Approach.part3.rar
3.81 MB, 下载次数: 253 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Acoustic Echo and Noise Control A Practical Approach.part4.rar
3.81 MB, 下载次数: 296 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-3-20 19:05:33 | 显示全部楼层
5part
Acoustic Echo and Noise Control A Practical Approach.part5.rar
2.83 MB, 下载次数: 352 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-3-20 19:07:21 | 显示全部楼层
第四本书:Noise, Oscillators and Algebraic Randomness
Book Description
Noise is ubiquitous in nature and in man-made systems. Noise in oscillators perturbs high-technology devices such as time standards or digital communication systems. The understanding of its algebraic structure is thus of vital importance. The book addresses both the measurement methods and the understanding of quantum, 1/f and phase noise in systems such as electronic amplifiers, oscillators and receivers, trapped ions, cosmic ray showers and in commercial applications. A strong link between 1/f noise and number theory is emphasized. The twenty papers in the book are comprehensive versions of talks presented at a school in Chapelle des Bois (Jura, France) held from April 6 to 10, 1999, by engineers, physisicts and mathematicians.
Book Info
Presents the lecture of a school held in Chapelle des Bois, France, April 5-10, 1999. The lectures address the algebraic structure of noise in digital communication systems, time standards, and other high-tech devices, looking at these subjects from a quantum physics and a fractal viewpoint. DLC: Electronic noise--Mathematical models--Congresses.
Product Details
Publisher: Springer; 1 edition (August 17, 2000)
Language: English
ISBN-10: 3540675728
ISBN-13: 978-3540675723
[ 本帖最后由 lxandlj 于 2008-3-20 19:12 编辑 ]
Noise, Oscillators and Algebraic Randomness.rar
2.44 MB, 下载次数: 306 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-3-25 23:02:32 | 显示全部楼层
这是好书这是好书
这是好书这是好书
发表于 2008-3-25 23:03:58 | 显示全部楼层
这是好书这是好书
这是好书这是好书这是好书
GMT+8, 2025-12-21 20:47 , Processed in 0.024831 second(s), 6 queries , Gzip On, Redis On.
