在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 210|回复: 3
求助,DVE在Ubuntu 20.04上无法运行
发表于 2024-5-4 11:49:08 | 显示全部楼层 |阅读模式
DVE  2018,2020,2022均报如下错误,但vcs可以正常运行
wangzh@800G6:~/test_eda$ dve -full64
Command line: /cad/synopsys/vcs/vcs/gui/dve/linux64/bin/dve.exe -full64
--- Stack trace follows:
ptrace: Operation not permitted.
/home/wangzh/test_eda/14823: No such file or directory.
/tmp/.stack_annotator_gdb_cmd_file_tR9F11:3: Error in sourced command file:
The program is not being run.
Process VmPeak: 270908 kb, VmSize: 211432 kb
System Free Memory: 57554192 kb, System Free Swap: 2097148 kb
No context available
如果换root,dve也可正常运行,不知何故?
有没有如到类似情况的?
发表于 2024-5-4 16:04:33 | 显示全部楼层
建议在centos(redhat) 上运行
发表于 2024-5-4 23:21:25 | 显示全部楼层
新的 ubuntu 需要权限才能运行 ptrace
尝试跑
  1. $ echo 0 | sudo tee /proc/sys/kernel/yama/ptrace_scope
复制代码
然后在没有root的情况下运行dve
 楼主| 发表于 2024-5-5 09:33:38 | 显示全部楼层
按照3楼的办法,还是不行,反馈如下
[New LWP 19111]
BFD: warning: /lib/x86_64-linux-gnu/libz.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libpthread.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libX11.so.6: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libXext.so.6: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libICE.so.6: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libm.so.6: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libdl.so.2: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libc.so.6: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib64/ld-linux-x86-64.so.2: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libxcb.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libuuid.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libbsd.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libXau.so.6: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libXdmcp.so.6: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libudev.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libdbus-glib-1.so.2: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libdbus-1.so.3: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libgio-2.0.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libgobject-2.0.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libglib-2.0.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libsystemd.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libgmodule-2.0.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libmount.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libselinux.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libresolv.so.2: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libpcre.so.3: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/librt.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/liblzma.so.5: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/liblz4.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libblkid.so.1: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libpcre2-8.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libgpg-error.so.0: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libnss_files.so.2: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libnss_dns.so.2: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libnss3.so: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libnssutil3.so: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libplc4.so: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/libplds4.so: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
BFD: warning: /lib/x86_64-linux-gnu/nss/libsoftokn3.so: unsupported GNU_PROPERTY_TYPE (5) type: 0xc0000002
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007f62033a423f in clock_nanosleep () from /lib/x86_64-linux-gnu/libc.so.6
Thread 2 (Thread 0x7f62024a8700 (LWP 19111)):
#0  0x00007f62033a9c7f in wait4 () from /lib/x86_64-linux-gnu/libc.so.6
#1  0x00007f6203318f67 in ?? () from /lib/x86_64-linux-gnu/libc.so.6
#2  0x00007f620587b5eb in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e639d2928478c79b3f673f99203bcf8be64600612100082236bffb2007f1e0ef9 () from /cad/synopsys/vcs/vcs/linux64/lib/liberrorinf.so
#3  0x00007f620587bc01 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e81c34e9ac4c8988ef4a6e067b3aa9271e9f15440f9e8f69ebc77e2fd65860faa () from /cad/synopsys/vcs/vcs/linux64/lib/liberrorinf.so
#4  0x00007f620587d18a in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313efba706aab251478fa49e66610e453774633a6c152e7ef778f2202cda681f3d4e () from /cad/synopsys/vcs/vcs/linux64/lib/liberrorinf.so
#5  0x00007f6205875642 in SNPSle_d35ca1ff70d465c2b9b1a72eee90a50630165806651fae961ce1525e42aba82d () from /cad/synopsys/vcs/vcs/linux64/lib/liberrorinf.so
#6  0x00007f620587ad39 in SNPSle_a616a49d50c972830e5a9fc3c8e619d38b78b0950f1d2e37 () from /cad/synopsys/vcs/vcs/linux64/lib/liberrorinf.so
#7  <signal handler called>
#8  0x0000000000000000 in ?? ()
#9  0x00007f6200fa2497 in mallocWithAlarm () from /cad/synopsys/vcs/vcs/linux64/lib/libsqlite3.so.0
#10 0x00007f6200fa25ab in sqlite3Malloc () from /cad/synopsys/vcs/vcs/linux64/lib/libsqlite3.so.0
#11 0x00007f6200fa25f9 in sqlite3_malloc () from /cad/synopsys/vcs/vcs/linux64/lib/libsqlite3.so.0
#12 0x00007f6200fa4db1 in sqlite3StrAccumFinish () from /cad/synopsys/vcs/vcs/linux64/lib/libsqlite3.so.0
#13 0x00007f6200fa51da in sqlite3_vmprintf () from /cad/synopsys/vcs/vcs/linux64/lib/libsqlite3.so.0
#14 0x00007f6200fa52c1 in sqlite3_mprintf () from /cad/synopsys/vcs/vcs/linux64/lib/libsqlite3.so.0
#15 0x00007f6201292361 in ?? () from /lib/x86_64-linux-gnu/nss/libsoftokn3.so
#16 0x00007f6201295fc5 in ?? () from /lib/x86_64-linux-gnu/nss/libsoftokn3.so
#17 0x00007f620127bcb7 in ?? () from /lib/x86_64-linux-gnu/nss/libsoftokn3.so
#18 0x00007f620127c11b in ?? () from /lib/x86_64-linux-gnu/nss/libsoftokn3.so
#19 0x00007f620127c968 in ?? () from /lib/x86_64-linux-gnu/nss/libsoftokn3.so
#20 0x00007f620127ccdc in ?? () from /lib/x86_64-linux-gnu/nss/libsoftokn3.so
#21 0x00007f620138cc52 in ?? () from /lib/x86_64-linux-gnu/libnss3.so
#22 0x00007f620138d3e9 in ?? () from /lib/x86_64-linux-gnu/libnss3.so
#23 0x00007f620139abcd in SECMOD_LoadModule () from /lib/x86_64-linux-gnu/libnss3.so
#24 0x00007f620139ad18 in SECMOD_LoadModule () from /lib/x86_64-linux-gnu/libnss3.so
#25 0x00007f620135f47b in ?? () from /lib/x86_64-linux-gnu/libnss3.so
#26 0x00007f620135f9fd in NSS_Init () from /lib/x86_64-linux-gnu/libnss3.so
#27 0x000000000122b507 in rfQdaMVz ()
#28 0x000000000112b079 in MAXpcKOd ()
#29 0x000000000112a0fa in BTkiHNFF ()
#30 0x0000000001127e4c in ?? ()
#31 0x0000000001128311 in yjuQOTfZ ()
#32 0x0000000001128427 in QMkLnvNl ()
#33 0x00007f6203da5609 in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#34 0x00007f62033e6353 in clone () from /lib/x86_64-linux-gnu/libc.so.6
Thread 1 (Thread 0x7f6203265740 (LWP 19104)):
#0  0x00007f62033a423f in clock_nanosleep () from /lib/x86_64-linux-gnu/libc.so.6
#1  0x00007f62033a9ec7 in nanosleep () from /lib/x86_64-linux-gnu/libc.so.6
#2  0x00007f62033a9dfe in sleep () from /lib/x86_64-linux-gnu/libc.so.6
#3  0x0000000000ee13c6 in IUet3h7dnSwDnmt ()
#4  0x0000000000ee156d in nAR8tWqFNRONMEo ()
#5  0x0000000000edf797 in pizBhiy39Ywj9j ()
#6  0x0000000000edfa65 in Vi9wVDbIr1poz5K ()
#7  0x0000000000eca642 in ?? ()
#8  0x0000000000eca94c in q4B4ASScVBC3CiY ()
#9  0x0000000000ecce5a in LZLo3lgWvbv8 ()
#10 0x0000000000ec5732 in c6obzhUAjviQHlJ ()
#11 0x0000000000ec5ab5 in S6d9TcUheexaJHD ()
#12 0x0000000000ec651d in scl_lc_checkout ()
#13 0x0000000000eb6012 in vcs_checkout ()
#14 0x0000000000eb28c4 in lDeleteFromSchedulerQ2 ()
#15 0x0000000000eab873 in ?? ()
#16 0x0000000000eac502 in tfdvsf_chk3 ()
#17 0x000000000133719f in ag:vaScl() ()
#18 0x0000000000ea8043 in main ()
Process VmPeak: 344720 kb, VmSize: 285244 kb
System Free Memory: 58553828 kb, System Free Swap: 2097148 kb
GMT+8, 2024-5-18 20:46 , Processed in 0.018975 second(s), 7 queries , Gzip On, Redis On.
