在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3452|回复: 44
[资料] Clock Tree Synthesis
发表于 2023-5-14 01:19:10 | 显示全部楼层 |阅读模式
Clock Tree Synthesis is a technique for distributing the clock equally among all sequential parts of a  VLSI design. The purpose of Clock Tree Synthesis is to reduce skew and delay. Clock Tree Synthesis is provided the placement data as well as the clock tree limitations as input output . Clock Tree Synthesis (CTS) is the technique of balancing the clock delay to all clock inputs by inserting buffers/inverters along the clock routes of an  ASIC design. As a result, CTS is used to balance the skew and reduce insertion latency. Before Clock Tree Synthesis, all clock pins were driven by a single clock source. Clock tree synthesis includes both clock tree construction and clock tree balance. Clock tree inverters may be used to create a clock tree that maintains the correct transition (duty cycle), and clock tree buffers (CTB) can balance the clock tree to fulfill the skew and latency requirements. To fulfill the space and power limits, fewer clock tree inverters and buffers should be employed.
Skew
Skew
Clock Tree Synthesis.pdf
3.5 MB, 下载次数: 382 , 下载积分: 资产 -2 信元, 下载支出 2 信元
CTS
发表于 2023-5-14 09:55:41 | 显示全部楼层
thanks
发表于 2023-5-14 11:05:34 | 显示全部楼层
Thank you very much.
发表于 2023-5-14 18:01:20 | 显示全部楼层
thanks for sharing
发表于 2023-5-14 20:06:09 | 显示全部楼层
谢谢
发表于 2023-5-14 20:16:55 | 显示全部楼层
thanks
发表于 2023-5-14 21:36:55 | 显示全部楼层
Thanks for sharing
发表于 2023-5-15 00:18:27 | 显示全部楼层
多谢分享
发表于 2023-5-15 16:20:59 | 显示全部楼层
3Q!!
发表于 2023-5-17 14:25:58 | 显示全部楼层
Thanks!
GMT+8, 2024-5-7 00:00 , Processed in 0.029506 second(s), 8 queries , Gzip On, Redis On.
