我通过下载“Cortex-M3 DesignStart FPGA XilinxEdition”软核,建立了一个自己的工程,由于我Keil软件部分的代码比较多,所以消耗了262144的memory size,所以我就把arm的ITCM的size调到了256KB,这样的话刚好差不多够用。但是,目前遇到的问题是,官方给的这个软核的例程,里面用于生成.mmi文件的tcl脚本,它对memory的限制是在16KB-128KB之间的,所以,我无法使用官方给的tcl生成.mmi文件。我尝试修改这个tcl文件,无奈总是出现其他别的问题。 开发板的资源是够用的。我现在的想法是需要生成一个.mmi文件,用于后面update合成一个新的bit文件。
以下是官方提供的脚本:
``` # ----------------------------------------------------------------------------- # The confidential and proprietary information contained in this file may # only be used by a person authorised under and to the extent permitted # by a subsisting licensing agreement from ARM limited. # # (C) COPYRIGHT 2018 ARM limited. # ALL RIGHTS RESERVED # # This entire notice must be reproduced on all copies of this file # and copies of this file may only be made by a person if such person is # permitted to do so under the terms of a subsisting license agreement # from ARM limited. # # SVN Information # # Checked In : $Date$ # # Revision : $Revision$ # # Release Information : Cortex-M3 DesignStart-r0p0-00rel0 # with V2C-DAPLink adaptor board # ----------------------------------------------------------------------------- # Purpose : # Script to get ITCM BRAM locations # MMI format from following two articles # # ----------------------------------------------------------------------------- # Set MMI output file name set mmi_file "m3.mmi" set part "xc7a200tfbg484-1" # Function to swap bits proc swap_bits { bit } { if { $bit > 23 } {return [expr {24 + (31 - $bit)}]} if { $bit > 15 } {return [expr {16 + (23 - $bit)}]} if { $bit > 7 } {return [expr {8 + (15 - $bit)}]} return [expr {7 - $bit}] } # If run from batch file, will need to open project, then open the run # open_run impl_1 # Find all the ITCM RAMs, place in a list set itcm_ram [get_cells -hier -regexp {.*u_x_itcm.*ram_block_reg.*} -filter {REF_NAME =~ RAMB36E1}] # Vivado appears to read the memories in their actual bit order # However update_mem amongst its very many failings doesn't support endianness, even though you specify it in the file! # It also pays no attention to the bit_lane definition, it does the conversion based on the order memories are defined # in the file! Not clear what the MMI file does achieve! # So go through and reverse each block of 4 memories if { [expr {[llength $itcm_ram] % 4}] != 0 } { puts "Error - Number of memories not divisible by 4" return -1 } # Number of RAMs details memory size. Each RAM is 32kb, so 4kB. set itcm_size_bytes [expr {4096*[llength $itcm_ram]}] puts "Instruction memory size $itcm_size_bytes" # Currently only support memory sizes between 16kB, (one byte per mem), and 128kB, (one bit per mem) if { ($itcm_size_bytes <= (4*4096)) || ($itcm_size_bytes > (32*4096)) } { puts "Error - Memory size of $itcm_size_bytes out of range" puts " Script only supports memory sizes between 16kB and 128kB" return -1 } # Create and open target mmi file set fp [open $mmi_file {WRONLY CREAT TRUNC}] if { $fp == 0 } { puts "Error - Unable to open $mmi_file for writing" return -1 } # Write the file header puts $fp "<?xml version=\"1.0\" encoding=\"UTF-8\"?>" puts $fp "<MemInfo Version=\"1\" Minor=\"15\">" puts $fp " <Processor Endianness=\"ignored\" InstPath=\"dummy\">" puts $fp " <AddressSpace Name=\"m3_for_arty_a7_i.Cortex_M3_0.inst.u_x_itcm\" Begin=\"0\" End=\"[expr {$itcm_size_bytes-1}]\">" puts $fp " <BusBlock>" # Create an array to put the location and top memory index into array set mem_array {} # Calculate the expected number of bits per memory set mem_bits [expr {32/[llength $itcm_ram]}] for {set i 0} {$i < [llength $itcm_ram]/4} {incr i} { set start [expr {$i*4}] set end [expr {($i*4)+3}] set new_list [lreverse [lrange $itcm_ram [expr {$i*4}] [expr {($i*4)+3}]]] # puts "$start $end\n$new_list" # lreplace $itcm_ram [expr {$i*4}] [expr {($i*4)+3}] [lreverse [lrange $itcm_ram [expr {$i*4}] [expr {($i*4)+3}]]] # puts $itcm_ram_reordered # For each entry display the location foreach ram $new_list { # Get the RAM location set loc_val [get_property LOC [get_cells $ram]] regexp -- {(RAMB36_)([0-9XY]+)} $loc_val full ram_name loc_xy # Get the nets driven by the D0 pins set data_bus [get_nets -of_objects [get_pins -filter {REF_PIN_NAME =~ DOADO*} -of [get_cells $ram]]] # Check number of bits is the same as that expected if { [llength $data_bus] != $mem_bits } { puts "Error - Number of data pins read, [llength $data_bus], does not equal expected memory bits, $mem_bits" return -1 } # Number of pins connected to the memory sets the memory depth. set memory_depth [expr {(32768/[llength $data_bus])-1}] foreach entry $data_bus { # Filter the data_bus down to just the two index numbers set index [regexp -inline -- {[0-9]+} [regexp -inline -- {\[.*} [lindex $entry 0]]] lappend idx_list $index } # Sort the index list from highest to lowest set idx_list [lsort -decreasing -integer $idx_list] # Assign the highest and lowest bits for the range variables set index_low [lindex $idx_list end] set index_high [lindex $idx_list 0] # Debug # puts $data_bus # puts $idx_list # puts "$index_high downto $index_low pos $loc_val" array set mem_array [list $index_high $loc_xy] }; # foreach }; # for # Sort array into index order array set mem_array_sorted {} foreach entry [lsort [array names mem_array]] { # puts "$entry : $mem_array($entry)" array set mem_array_sorted [list $entry $mem_array($entry)] } foreach entry [array names mem_array_sorted] { # puts "$entry : $mem_array_sorted($entry)" } # MMI file needs to be in little endian format because update_mem doesn't actually use the endianness field # So first index is 7, next is 15, 23, 31. # Number of entries to write is 8/mem_bits. Lower index is index_high - (mem_bits - 1) for {set top_idx 7} {$top_idx < 32} {incr top_idx 8} { for {set idx_high $top_idx} {$idx_high > ($top_idx-8)} {incr idx_high -$mem_bits} { # puts $idx_high set loc $mem_array_sorted($idx_high) set idx_low [expr {$idx_high - $mem_bits + 1}] if { $loc == "" } { puts "Error - No location entry for index $idx_high" return -1 } # Write relevant XML puts $fp " <BitLane MemType=\"RAMB36\" Placement=\"$loc\">" puts $fp " <DataWidth MSB=\"$idx_high\" LSB=\"$idx_low\"/>" puts $fp " <AddressRange Begin=\"0\" End=\"$memory_depth\"/>" puts $fp " <Parity ON=\"false\" NumBits=\"0\"/>" puts $fp " </BitLane>" } } # Write the file tail puts $fp " </BusBlock>" puts $fp " </AddressSpace>" puts $fp " </Processor>" puts $fp " <Config>" puts $fp " <Option Name=\"Part\" Val=\"$part\"/>" puts $fp " </Config>" puts $fp " <DRC>" puts $fp " <Rule Name=\"RDADDRCHANGE\" Val=\"false\"/>" puts $fp " </DRC>" puts $fp "</MemInfo>" # Close the output file close $fp # Useful facilities # Get the bus as a list # get_nets -hierarchical -regexp {.*itcm.*doutA.*} ``` 如果直接运行,那肯定是不行的,会出现以下错误: ``` Error - Memory size of 262144 out of range Script only supports memory sizes between 16kB and 128kB -1 ``` 请教以下各位,该如何修改这个tcl文件,或者有什么其他的方法可以生成.mmi文件。网上提供的方法我试了,总是行不通,害。
