查看: 8486|回复: 5
[求助] lattice利用vcs仿真库添加不上
发表于 2020-2-8 16:56:44 | 显示全部楼层 |阅读模式
悬赏200资产未解决
vcs错误提升如下所示:
Error-[CFCILFBI] Cannot find cell in liblist
./../../rtl/TOP/top.v, 88
  Cell 'OSCI' cannot be found in liblist for binding instance.
  Liblist: work
添加库如下所示:1.        Create local folder for the work library:
mkdir work2.        Create (or modify) your local synopsys_sim.setup file, and add the following lines:
WORK > DEFAULTDEFAULT : ./work3.        Analyze the machxo2_black_boxes modules from their encrypted Verilog source file as follows:
vlogan +v2k <install_dir>/cae_library/simulation/blackbox/machxo2_black_boxes-vcs.vp4.        Compile your SystemVerilog files and simulate your design with top-level unit (test bench):
vcs -mhdl -RI <design_name>.v <test_bench>.v -y <install_dir>/cae_library/simulation/Verilog/machxo2 +libext+.v
请教如下才能在vcs上添加lattice  black_boxes的库?
发表于 2020-2-16 19:01:36 | 显示全部楼层
Probably you have to add crystal specific compiled libraries to simulator/
发表于 2020-2-25 13:21:34 | 显示全部楼层
thankss
发表于 2020-3-8 04:31:16 | 显示全部楼层
thank you for sharing
 楼主| 发表于 2020-3-9 09:39:04 | 显示全部楼层
到此为止了,我已经找到答案了
发表于 2020-8-7 18:03:59 来自手机 | 显示全部楼层
怎么解决的,求分享
GMT+8, 2025-12-18 00:22 , Processed in 0.020836 second(s), 3 queries , Gzip On, Redis On.
