查看: 11739|回复: 9
[求助] lattice利用vcs仿真 库添加不进去问题
发表于 2020-2-8 16:52:33 | 显示全部楼层 |阅读模式
悬赏200资产未解决
vcs错误提示如下:
Error-[CFCILFBI] Cannot find cell in liblist
./../../rtl/TOP/top.v, 88
  Cell 'OSCI' cannot be found in liblist for binding instance.
  Liblist: work
库添加编译如下所示
1.        Create local folder for the work library:
mkdir work2.        Create (or modify) your local synopsys_sim.setup file, and add the following lines:
WORK > DEFAULTDEFAULT : ./work3.        Analyze the machxo2_black_boxes modules from their encrypted Verilog source file as follows:
vlogan +v2k <install_dir>/cae_library/simulation/blackbox/machxo2_black_boxes-vcs.vp4.        Compile your SystemVerilog files and simulate your design with top-level unit (test bench):
vcs -mhdl -RI <design_name>.v <test_bench>.v -y <install_dir>/cae_library/simulation/Verilog/machxo2 +libext+.v
请问lattice  black_boxes的库怎么样添加在VCS上?
发表于 2020-2-9 13:13:00 | 显示全部楼层
谢谢
发表于 2020-2-9 15:51:44 | 显示全部楼层
谢谢
发表于 2020-2-9 16:41:28 | 显示全部楼层
学习一下
发表于 2020-9-23 10:10:59 | 显示全部楼层
怎么解决的啊
发表于 2020-9-23 10:23:44 | 显示全部楼层
怎么解决
发表于 2020-11-10 21:17:24 | 显示全部楼层
有 lattice 软件吗?  可以分享吗?
发表于 2021-7-14 11:34:24 | 显示全部楼层
发表于 2021-12-7 15:03:47 | 显示全部楼层
请问一下楼主是怎么解决的
 楼主| 发表于 2021-12-13 14:03:28 | 显示全部楼层
fangnime 发表于 2021-12-7 15:03
请问一下楼主是怎么解决的
放弃,转投modelsim
GMT+8, 2025-12-9 08:28 , Processed in 0.018663 second(s), 3 queries , Gzip On, Redis On.
