331 layout instances were filtered and their pins removed from adjoining nets.
102699 layout mos transistors were reduced to 34960. 10851 connecting nets were deleted.
48380 mos transistors were deleted by parallel reduction.
19359 mos transistors and 10851 connecting nets were deleted by split-gate reduction.
37991 source mos transistors were reduced to 11981. 10851 connecting nets were deleted.
6651 mos transistors were deleted by parallel reduction.
4 parallel layout diodes were reduced to 1.
4 parallel source diodes were reduced to 1.
1 layout net had all its pins removed and was deleted.
8121 source nets had all their pins removed and were deleted.
