查看: 5080|回复: 0
porting ucosii遇到的问题
发表于 2007-11-14 11:21:06 | 显示全部楼层 |阅读模式
大家好,我是一个embedded system方面的初学者,前阵子阅读完邵贝贝关于ucos的书,就开始练习porting ucosii on MIPS。
我所用的开发板上主IC是一款source decoder,面向的是low cost的STB或者DTV应用,它内嵌了一个32-bit MIPS RISC架构的CPU,兼容MIPS-II ISA和MIPS16指令集。
作为porting的第一阶段,我是想让ucosii kernel能够正常的运行,创建两个简单的task,相互之间通过通过一个semophore进行通信,打印出一些字符(我是在cygwin下建立的交叉编译环境)。
但是现在我遇到的问题是,在assembly code里做完一系列CPU和外围相关的初始化工作之后,跳转到C的main函数里面Initialize board和ucosii kernel时,程序就会dead,
我怀疑是create stack,exception,interrupt的问题,查阅了seemipsrun的相关章节,仍然没有得到答案
   所以,希望MIPS开发的大虾们能够给我一些指点,以下是我entry的assembly code,大家给些建议把,谢谢啦。
#include <archdefs.h>
#include <frmwrk.h>
#include <cpu1910.h>
#include <derk_board.h>
#include <memory.h>
/* Global definitions */
   .extern InitDebug
   .extern Erase_Sdram
*                                       _start
* Description: This routine configs MIPS CPU, enable big endianess,
*              and starts the application C code.
* Arguments  : none
* Return     : none.
* Note(s)    : Function linked to application start address.
      .globl _start
      .ent   _start
_start:
      .set noreorder
        nop
        nop
        nop
        nop
        nop
        nop
        nop
        nop
        b       1f
        nop
1:      nop
        nop
        nop
      # Setup gp #
      la    gp, _gp
#    Basic configuration of the CPU                                  *
          #    CONFIG REGISTER  #
            mfc0    t0, C0_CONFIG_1910                         # Read config register
            nop                                                           # Branch delay slot
            or      t0, END_CONFIG_REG                         # big endianess
            or      t0, (DSU_CONFIG_REG | MIPS16_CONFIG_REG)   # Enable Debug Support
        # Unit and MIPS16 inst
            and     t0, ~(MAP_CONFIG_REG )                               # MAP translation sheme 2
        # Disable
            or      t0, (ICD_CONFIG_REG | DCD_CONFIG_REG)      # Disable both caches
        # access
            and     t0, ~(ST1_CONFIG_REG  | ST2_CONFIG_REG)    # Enable the counter1 and the counter 2
            mtc0    t0, C0_CONFIG_1910                                   # Write config register
#   initialize the general purpose registers
            or      $1,     $0,     $0
            or      $2,     $0,     $0
            or      $3,     $0,     $0
            or      $4,     $0,     $0
            or      $5,     $0,     $0
            or      $6,     $0,     $0
            or      $7,     $0,     $0
            or      $8,     $0,     $0
            or      $9,     $0,     $0
            or      $10,    $0,     $0
            or      $11,    $0,     $0
            or      $12,    $0,     $0
            or      $13,    $0,     $0
            or      $14,    $0,     $0
            or      $15,    $0,     $0
            or      $16,    $0,     $0
            or      $17,    $0,     $0
            or      $18,    $0,     $0
            or      $19,    $0,     $0
            or      $20,    $0,     $0
            or      $21,    $0,     $0
            or      $22,    $0,     $0
            or      $23,    $0,     $0
            or      $24,    $0,     $0
            or      $25,    $0,     $0
            or      $26,    $0,     $0
            or      $27,    $0,     $0
            or      $28,    $0,     $0
            or      $29,    $0,     $0
            or      $30,    $0,     $0
            or      $31,    $0,     $0
#   initialize the  CP0 Read registers.
            mtc0     $0,     C0_CAUSE
            mtc0     $0,     C0_EPC
            mtc0     $0,     C0_DESAVE_1910
#*      Disable the interrupt and init boot strap.                      *
#   STATUS REGISTER                                                 #
    mfc0    t0,    C0_Status                       # Read Status register
    and     t0,    ~(SR_IT_MASK | SR_BEV)      # Mask ITs and
                                                # boot strap vector
                                                # locations are used
    mtc0    t0,    C0_Status                       # Write Status register
#   Enable the GPIO to output the UARTS signals
    li      t1,    GPIO_SEL_RESET_VALUE
    li      t2,    GPIO_BASE_ADDRESS
    sw      t1,    GPIO_SEL_OFFSET(t2)
#  Erase SDRAM -- not working so far #
     jal     Erase_Sdram
     nop
#  create temporary stack on the top of uncached memory#
      la    sp,    _freemem    # put stack pointer on top
                                        # of memory
      li    t5,    KSEG1BASE
      or    sp,    sp, t5                                    # Uncache stack pointer
      subu  t0,    sp, _SYS_STKSIZE                     # substract stack size to
                                                              # stack pointer
2:
      sw      zero,  0(t0)               # clear stack
      bltu    t0,    sp, 2b              # Loop
      addiu    t0,    4                  # Branch delay slot
#          Print the debug infos #
          jal   InitDebug   # already work
          nop
#   Initialize caches
                jal   InitCaches
                nop
#*      Do startup initialization that can't be done in C.                      *
#   Clear bss #
      la    t0, _fbss        /* First address */
      la    t1, _end        /* Last  address */
                        1:
      sw    zero, 0(t0)
      bne   t0, t1, 1b
      addiu t0, 4
#   Install exceptions handlers
                jal   EXCEP_vInstallExcInRam
                nop
                jal   EXCEP_vInstallIntInRam
                nop
#   Create stack on the top of cached memory
      la    sp,    _freemem
      subu  t0,    sp, STACKSIZE                     # substract stack size to
                                        # stack pointer
2:
      # Align sp to 16 byte boundary (required by Cygnus) #
      li    t0, ~0xf
      and   sp, t0
      # Get ready to jump to main #
      move  s0, ra
      la    t0, C_vMain
      # Jump to main #
      jalr   t0
      nop
      # Return #
      jr    s0
      nop
      .set reorder
      .end   _start
GMT+8, 2025-12-24 01:27 , Processed in 0.024206 second(s), 7 queries , Gzip On, Redis On.
