在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 39144|回复: 76
[求助] Innovus 教程下载/Innovus lab下载/Innovus userguide下载
发表于 2018-1-23 15:11:38 | 显示全部楼层 |阅读模式
6666资产
请问有朋友有Cadence的账号么?能否帮忙下载一下 Cadence的《Intro to Innovus15.1 and Block Implementation Flow RAK》这一套实验,谢谢~重酬!5个实验中的其中一个pdf我已经传上去了,第4页蓝色字部分就是下载链接。下面我也把下载链接贴上来~
Floorplanning the Design chapter of the Innovus User Guide
地址:http://support.cadence.com/wps/m ... linkmin:TechPubDocs;src=pubs;q=/innovusUG/innovusUG15.12/Floorplanning_the_Design.html
Automatic Floorplan Synthesis chapter of the Innovus User Guide
地址: http://support.cadence.com/wps/m ... linkmin:TechPubDocs;src=pubs;q=/innovusUG/innovusUG15.12/Creating_An_Initial_Floorplan_Using_Automatic_Floorplan_Synthesis.html
Power Planning and Routing chapter of the Innovus User Guide
地址: http://support.cadence.com/wps/m ... linkmin:TechPubDocs;src=pubs;q=/innovusUG/innovusUG15.12/Power_Planning_and_Routing.html
Prototyping Foundation Flat Flow Rapid Adoption Kit (RAK)
地址:http://support.cadence.com/wps/mypoc/cos?uri=deeplinkminocumentViewer;src=wp;q=ProductInformation/Digital_IC_Design/ApplicationPackages/ICD_RAK_Home.htm
Intro to Innovus 15.1 and Block Implementation Flow (RAK)
这是对于这个实验的介绍
The Floorplanning Rapid Adoption Kit (RAK) introduces you to the basic floorplanning features of Innovus. It is very basic by design so we highly recommend users attend one of the several Innovus training classes provided by Cadence Educational Services. For more information on available training please visit www.cadence.com and click Support & Training.
Floorplanning involves defining the size of the chip or block, pre-placing hard macros, IO pads and other desired objects and defining a power grid for the design. Innovus floorplanning capabilities range from automated methods such as the Prototyping Foundation Flow and Automatic Floorplan Synthesis down to manual control with Relative Floorplanning and the Floorplan Toolbox which provides pinpoint control of macro placements. The automatic floorplan features allow you to converge on a floorplan quickly for designs containing hundreds of hard macros while the manual control provide
the fine tuning required to finalize the floorplan.
In this module you will be introduced to the basic floorplanning features to place hard macros and complete the power plan resulting in a design that is ready for place and route implementation. You can continue your learning by referencing the following resources. If you are new to Innovus it’s highly recommended you complete the Intro to Innovus 15.1 and Block Implementation Flow RAK:
 Floorplanning the Design chapter of the Innovus User Guide
 Automatic Floorplan Synthesis chapter of the Innovus User Guide
 Power Planning and Routing chapter of the Innovus User Guide
 Prototyping Foundation Flat Flow Rapid Adoption Kit (RAK)
 Intro to Innovus 15.1 and Block Implementation Flow (RAK)
有Cadence账号的好心朋友麻烦帮我下载一下,咱们可以微信联系,微信号:omg123456321omg
Floorplanning151_Lab.pdf
1.68 MB, 下载次数: 870 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2018-1-24 16:53:28 | 显示全部楼层
终于可以脱离每次下都要回复的命运了
发表于 2018-2-2 19:31:56 | 显示全部楼层
我还没有摆脱
发表于 2018-2-3 09:08:53 | 显示全部楼层
Thanks
发表于 2018-2-6 09:27:28 | 显示全部楼层
Thanks
发表于 2018-2-7 19:29:03 | 显示全部楼层
Thanks... good compilation of the links...
发表于 2018-2-11 15:58:25 | 显示全部楼层
帮顶,如果楼主有结果了,麻烦分享一下。谢谢。。
发表于 2018-2-14 09:39:34 | 显示全部楼层
我有这个!你要?
发表于 2018-2-19 12:02:38 | 显示全部楼层
回复 1# GarryTse
    thanks for sharing
发表于 2018-2-22 23:35:33 | 显示全部楼层
GMT+8, 2024-4-26 12:46 , Processed in 0.042712 second(s), 6 queries , Gzip On, Redis On.
