楼主 |
发表于 2018-4-2 14:04:48
显示全部楼层
回复 1# helimpopo
BUFRAM128C模块有点问题,用下面这个:
//// FFT/IFFT 128 points transform ////
//// Authors: Anatoliy Sergienko, Volodya Lepeha ////
//// Company: Unicore Systems http://unicore.co.ua ////
//// Downloaded from: http://www.opencores.org ////
//// Copyright (C) 2006-2010 Unicore Systems LTD ////
//// www.unicore.co.ua ////
//// o.uzenkov@unicore.co.ua ////
//// This source file may be used and distributed without ////
//// restriction provided that this copyright statement is not ////
//// removed from the file and that any derivative work contains ////
//// the original copyright notice and the associated disclaimer.////
//// THIS SOFTWARE IS PROVIDED "AS IS" ////
//// AND ANY EXPRESSED OR IMPLIED WARRANTIES, ////
//// INCLUDING, BUT NOT LIMITED TO, THE IMPLIED ////
//// WARRANTIES OF MERCHANTABILITY, NONINFRINGEMENT ////
//// AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. ////
//// IN NO EVENT SHALL THE UNICORE SYSTEMS OR ITS ////
//// CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, ////
//// INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL ////
//// DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT ////
//// OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, ////
//// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) ////
//// HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, ////
//// WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT ////
//// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING ////
//// IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, ////
//// EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ////
// DESCRIPTION
Store buffer
// FUNCTION:
FIFO - buffer with direct input order and 8-th inverse output order
FILES:
BUFRAM128C_2.v
- 1-st,2-nd,3-d data buffer, contains:
RAM2x128C.v - dual ported synchronous RAM, contains:
RAM128.v -single ported synchronous RAM
// PROPERTIES: 1) Has the volume of 2x128 complex data
2) Contains 2- port RAM and address counter
3)Has 128-clock cycle period starting with the START impulse
// and continuing forever
4) Signal RDY precedes the 1-st correct datum outputted from the buffer
`timescale 1 ns / 1 ps
`include "FFT128_CONFIG.inc"
module BUFRAM128C ( CLK ,RST ,ED ,START ,DR ,DI ,RDY ,DOR ,DOI );
`FFT128paramnb
output RDY ;
reg RDY ;
output [nb-1:0] DOR ;
wire [nb-1:0] DOR ;
output [nb-1:0] DOI ;
wire [nb-1:0] DOI ;
input CLK ;
wire CLK ;
input RST ;
wire RST ;
input ED ;
wire ED ;
input START ;
wire START ;
input [nb-1:0] DR ;
wire [nb-1:0] DR ;
input [nb-1:0] DI ;
wire [nb-1:0] DI ;
wire odd, we;
wire [6:0] addrw,addrr;
reg [7:0] addr;
reg [8:0] ct2;
//counter for the RDY signal
always @(posedge CLK)
// CTADDR
begin
if (RST) begin
addr<=7'b000_0000;
ct2<= 8'b1000_0001;
RDY<=1'b0; end
else if (START) begin
addr<=7'b000_0000;
ct2<= 8'b0000_0000;
RDY<=1'b0;end
else if (ED)
begin
RDY<=1'b0;
addr<=addr+1;
if (ct2!=129)
ct2<=ct2+1;
if (ct2==128)
RDY<=1'b1;
end
end
assign
addrw=
addr[6:0];
assign
odd=addr[7];
// signal which switches the 2 parts of the buffer
assign
addrr={addr[2 : 0], addr[6 : 3]};
// 8-th inverse output address
assign
we = ED;
RAM2x128C #(nb)
URAM(.CLK(CLK),.ED(ED),.WE(we),.ODD(odd),
.ADDRW(addrw),
.ADDRR(addrr),
.DR(DR),.DI(DI),
.DOR(DOR),
.DOI(DOI));
endmodule
有个RAM交换位置需要改一下。
