在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 4758|回复: 4
[求助] 有关uvm验证的问题
发表于 2017-5-23 11:23:37 | 显示全部楼层 |阅读模式
  1. `timescale 1ns/1ps
  2. `include "uvm_pkg.sv"
  3. module top_tb;
  4. import uvm_pkg::*;
  5. `include "uvm_macros.svh"
  6. reg clk;
  7. reg rst_n;
  8. reg[7:0] rxd;
  9. reg rx_dv;
  10. wire[7:0] txd;
  11. wire tx_en;
  12. class my_driver extends uvm_driver;
  13.   function new(string name = "my_driver", uvm_component parent = null);
  14.     super.new(name, parent);
  15.   endfunction
  16.   extern virtual task main_phase(uvm_phase phase);
  17.
  18. endclass
  19. task my_driver::main_phase(uvm_phase phase);
  20.    top_tb.rxd <= 8'b0;
  21.    top_tb.rx_dv <= 1'b0;
  22.    while(top_tb.rst_n)
  23.       @(posedge top_tb.clk);
  24.    for(int i = 0; i < 256; i++)begin
  25.       @(posedge top_tb.clk);
  26.       top_tb.rxd <= $urandom_range(0, 255);
  27.       top_tb.rx_dv <= 1'b1;
  28.       `uvm_info("my_driver", "data is drived", UVM_LOW)
  29.    end
  30.    @(posedge top_tb.clk);
  31.    top_tb.rx_dv <= 1'b0;
  32. endtask
  33. dut my_dut(.clk(clk),
  34.            .rst_n(rst_n),
  35.            .rxd(rxd),
  36.            .rx_dv(rx_dv),
  37.            .txd(txd),
  38.            .tx_en(tx_en));
  39. initial begin
  40.    my_driver drv;
  41.    drv = new("drv", null);
  42.    drv.main_phase(null);
  43.    // $finish();
  44.          // rxd = 200;
  45.          // rx_dv = 0;
  46.          // @(posedge rst_n);
  47.          // rxd = 255;
  48.          // rx_dv = 1;
  49. end
  50. initial begin
  51.    clk = 0;
  52.    forever begin
  53.       #100 clk = ~clk;
  54.    end
  55. end
  56. initial begin
  57.    rst_n = 1'b0;
  58.    #1000;
  59.    rst_n = 1'b1;
  60. end
  61. endmodule
复制代码
我将上面这个类定义在内部的时候可以正常仿真为什么我单独定义的时候就不能使用了呢?
  1. `ifndef MY_DRIVER__SV
  2. `define MY_DRIVER__SV
  3. class my_driver extends uvm_driver;
  4.    function new(string name = "my_driver", uvm_component parent = null);
  5.       super.new(name, parent);
  6.    endfunction
  7.    extern virtual task main_phase(uvm_phase phase);
  8. endclass
  10.    top_tb.rxd <= 8'b0;
  11.    top_tb.rx_dv <= 1'b0;
  12.    while(!top_tb.rst_n)
  13.       @(posedge top_tb.clk);
  14.    for(int i = 0; i < 256; i++)begin
  15.       @(posedge top_tb.clk);
  16.       top_tb.rxd <= $urandom_range(0, 255);
  17.       top_tb.rx_dv <= 1'b1;
  18.       `uvm_info("my_driver", "data is drived", UVM_LOW)
  19.    end
  20.    @(posedge top_tb.clk);
  22. endtask
  23. `endif
复制代码
我使用的是linux环境,questasim10.3a。do文件如下:
  1. set  UVM_DPI_HOME   /opt/mentor_graphics/questa/10.3a/questasim/uvm-1.1d/linux_x86_64
  2. vlib work
  3. vmap work
  4. vlog  +incdir+/opt/mentor_graphics/questa/10.3a/questasim/verilog_src/uvm-1.1d/src -L mtiAvm -L mtiOvm -L mtiUvm -L mtiUPF  top_tb.sv
  5. vlog  +incdir+/opt/mentor_graphics/questa/10.3a/questasim/verilog_src/uvm-1.1d/src -L mtiAvm -L mtiOvm -L mtiUvm -L mtiUPF  dut.sv
  6. vlog  +incdir+/opt/mentor_graphics/questa/10.3a/questasim/verilog_src/uvm-1.1d/src -L mtiAvm -L mtiOvm -L mtiUvm -L mtiUPF  my_driver.sv
  7. vsim  -ldflags "-lregex" -t 1ns -c -sv_lib $UVM_DPI_HOME/uvm_dpi -voptargs=+acc -L lpm_ver -L altera_mf_ver -L altera_ver -L stratixv_ver work.top_tb
  8. set StdArithNoWarnings 1
  9. set NumericStdNoWarnings 1
复制代码
发表于 2017-5-24 14:21:00 | 显示全部楼层
试试先编译my_driver.sv,再编译top_tb.sv看看?
 楼主| 发表于 2017-5-24 14:26:01 | 显示全部楼层
回复 2# gaurson
效果差不多,error信号如下
  1. # ** Error: my_driver.sv(3): near "uvm_driver": syntax error, unexpected IDENTIFIER
  2. # ** Error: my_driver.sv(3): Error in class extension specification.
复制代码
发表于 2017-5-24 16:42:03 | 显示全部楼层
加到my_driver.sv里边试试
 楼主| 发表于 2017-5-25 08:25:10 | 显示全部楼层
回复 4# songnp
谢谢,这下可以了
GMT+8, 2025-7-2 11:22 , Processed in 0.019744 second(s), 8 queries , Gzip On, MemCached On.
