用VCS来仿真xilinx生成的mig模块,一直出错。 配置信息如下: os : Red hat 6.4 mig : mig 7 series v2.3 vcs : vcs-mx_vG-2012.09 Testbench from example design sim_tb_top. Use script file : vcs_run.sh (auto generate). 结果: "TEST FAILED: INITIALION DID NOT COMPLETE." The result have some warnings: Warning -[TFIPC] Two few instance port connections. Warning -[PCWM-W] Port connection width mismatch. Warning -[STASKW_CO] cannot open file ***** Warning: The Analog data file design.txt for XADC instance sim_tb_top.u_ip_top.u_mig.u_mig_mig.temp_mon_enabled.u_tempmon.xadc_supplied_temperature.XADC_inst was not fond.Use the SIM_MONITOR_FILE parameter to specify the analog data file name or use the default name: design.txt. OTHES warnings: WARNING: 200 us is required before RST_N goes inactive. WARNING: 500 us is required before RST_N goes inactive before CKE goes active. 有谁遇到过这个问题,求帮助???? |
