整个过程都是按照坛上的方法安装的,但是安装完之后出现这个问题怎么回事?我的系统是RHEL 6.4
谢谢大家了startdate:Fri Feb 13 21:18:32 2015
crashdate:Fri Feb 13 21:18:39 2015
appname:virtuoso
version (#)$CDS: virtuoso version 6.1.6 01/19/2015 20:41 (sjfnl169) $
subversion:IC6.1.6.500.10
mem:123305984 (total 1952514048)
memavail:5524308k (total 6002744k)
signal:SegFault(11)
user:neil
host:neil (x86_64)
os inux
osversion: 2.6.32-358.el6.x86_64 #1 SMP Tue Jan 29 11:47:41 EST 2013 x86_64
xserver:CentOS
xversion:11.0 (vendor release 11500000)
display::0.0
qtversion:4.7.2
cdslog:/tmp/crashReport_021315_2118_IC6.1.6.500.10_neil_neil.log.CDS.log
signal_by:system
stack::__kernel_rt_sigreturn+0()
stack:virtuoso:cds_pl_check+2934()
stack:virtuoso:cdsPCheck+1134()
stack:virtuoso:ddsInit+65()
stack:libil_sh.so:iliInitClients+913()
stack:virtuoso:main+783()
stack ocal time (crash) Friday 13 February 2015, 09:18:39 PMLocal time (crash) Friday 13 February 2015, 09:18:39 PM
userenv:A__z="*SHLVL
userenv:CDNS_QTDIR=/home/neil/cadence/ic616/tools/Qt/32bit
userenv:CDS=/home/neil/cadence/ic616
userenv:CDS_ARCH=lnx86
userenv:CDS_LANG=en_US.utf8
userenv:CDS_LIC_FILE=5280@neil
userenv:CDS_MPS_SESSION=virtuoso2987
userenv:CDS_Netlisting_Mode=Analog
userenv:CDS_SET_LOCALE=C
userenv:COLORTERM=gnome-terminal
userenv:CVS_RSH=ssh
userenv BUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-ELe4VwdiJZ,guid=1462b671c8099052e95ea2400000007e
userenv D_NO_TMPDIR_WARN=true
userenv ESKTOP_SESSION=gnome
userenv:DISPLAY=:0.0
userenv:GDMSESSION=gnome
userenv:GDM_KEYBOARD_LAYOUT=us
userenv:GDM_LANG=en_US.utf8
userenv:GNOME_DESKTOP_SESSION_ID=this-is-deprecated
userenv:GNOME_KEYRING_PID=2683
userenv:GNOME_KEYRING_SOCKET=/tmp/keyring-GUawOA/socket
userenv:GTK_RC_FILES=/etc/gtk/gtkrc:/home/neil/.gtkrc-1.2-gnome2
userenv:G_BROKEN_FILENAMES=1
userenv:HISTCONTROL=ignoredups
userenv:HISTSIZE=1000
userenv:HOME=/home/neil
userenv:HOSTNAME=neil
userenv ANG=C
userenv:LC_ALL=C
userenv:LD_LIBRARY_PATH=/home/neil/cadence/ic616/tools/lib:/home/neil/cadence/ic616/tools/Qt/32bit/lib:/home/neil/cadence/ic616/oa_v22.43.042/lib/linux_rhel50_gcc44x_32/opt:/home/neil/cadence/ic616/tools/dfII/lib:/home/neil/cadence/ic616/tools/sev/lib:/home/neil/cadence/ic616/tools/inca/lib
userenv:LESSOPEN=|/usr/bin/lesspipe.sh %s
userenv:LM_LICENSE_FILE=/home/neil/cadence/ic616/share/license/license.dat
userenv:LOGNAME=neil
userenv:MAIL=/var/spool/mail/neil
userenv:MMSIM_ROOT=/home/neil/cadence/mmsim13
userenv:MOZILLA_HOME=/usr/bin/netscape
userenv:OA_BIT=32
userenv:OA_HOME=/home/neil/cadence/ic616/oa_v22.43.042/
userenv:ORBIT_SOCKETDIR=/tmp/orbit-neil
userenv ATH=/home/neil/cadence/ic616/bin:/home/neil/cadence/ic616/tools/bin:/home/neil/cadence/ic616/oa_v22.43.042//bin:/home/neil/cadence/mmsim13/tools/bin:/home/neil/cadence/mmsim13/tools/spectre/bin:/home/neil/cadence/ic616/tools/dfII/bin:/home/neil/cadence/mmsim13/tools/bin:/home/neil/cadence/mmsim13/tools/spectre/bin:/home/neil/cadence/ic616/tools/dfII/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/neil/bin
userenv WD=/home/neil/Desktop
userenv TDIR=/usr/lib64/qt-3.3
userenv TINC=/usr/lib64/qt-3.3/include
userenv TLIB=/usr/lib64/qt-3.3/lib
userenv:SHELL=/bin/bash
userenv:SHLVL=6
userenv:SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
userenv:SSH_AUTH_SOCK=/tmp/keyring-GUawOA/socket.ssh
userenv:TERM=xterm
userenv:USER=neil
userenv:USERNAME=neil
userenv:W3264_ENV=/home/neil/.kshrc
userenv:WINDOWID=44040370
userenv:WINDOWPATH=1
userenv:XAUTHORITY=/var/run/gdm/auth-for-neil-uQ1bjo/database
userenv:XDG_SESSION_COOKIE=70dee936b5f3a0959330e31300000042-1423890861.693390-1113179432
userenv:XTAPPPEEKEVENT_SKIPTIMER=1
userenv:_=*2987*/home/neil/cadence/ic616/tools/bin/32bit/cdsCrashReport
userenv:__DFII_INTEG_NC_PATH__=/home/neil/cadence/ic616/tools/inca/bin
userenv:_dfII_bin_bit=
userenv:df2BaseVhdlin=/home/neil/cadence/ic616
xdpyinfo:name of display: :0.0
xdpyinfo:version number: 11.0
xdpyinfo:vendor string: CentOS
xdpyinfo:vendor release number: 11500000
xdpyinfo:maximum request size: 16777212 bytes
xdpyinfo:motion buffer size: 256
xdpyinfo:bitmap unit, bit order, padding: 32, LSBFirst, 32
xdpyinfo:image byte order: LSBFirst
xdpyinfo:number of supported pixmap formats: 7
xdpyinfo:supported pixmap formats:
xdpyinfo: depth 1, bits_per_pixel 1, scanline_pad 32
xdpyinfo: depth 4, bits_per_pixel 8, scanline_pad 32
xdpyinfo: depth 8, bits_per_pixel 8, scanline_pad 32
xdpyinfo: depth 15, bits_per_pixel 16, scanline_pad 32
xdpyinfo: depth 16, bits_per_pixel 16, scanline_pad 32
xdpyinfo: depth 24, bits_per_pixel 32, scanline_pad 32
xdpyinfo: depth 32, bits_per_pixel 32, scanline_pad 32
xdpyinfo:keycode range: minimum 8, maximum 255
xdpyinfo:focus: window 0x4600053, revert to PointerRoot
xdpyinfo:number of extensions: 30
xdpyinfo: BIG-REQUESTS
xdpyinfo: Composite
xdpyinfo: DAMAGE
xdpyinfo: DOUBLE-BUFFER
xdpyinfo: DPMS
xdpyinfo: DRI2
xdpyinfo: GLX
xdpyinfo: Generic Event Extension
xdpyinfo: MIT-SCREEN-SAVER
xdpyinfo: MIT-SHM
xdpyinfo: Present
xdpyinfo: RANDR
xdpyinfo: RECORD
xdpyinfo: RENDER
xdpyinfo: SECURITY
xdpyinfo: SGI-GLX
xdpyinfo: SHAPE
xdpyinfo: SYNC
xdpyinfo: VMWARE_CTRL
xdpyinfo: X-Resource
xdpyinfo: XC-MISC
xdpyinfo: XFIXES
xdpyinfo: XFree86-DGA
xdpyinfo: XFree86-VidModeExtension
xdpyinfo: XINERAMA
xdpyinfo: XINERAMA
xdpyinfo: XInputExtension
xdpyinfo: XKEYBOARD
xdpyinfo: XTEST
xdpyinfo: XVideo
xdpyinfo:default screen number: 0
xdpyinfo:number of screens: 1
xdpyinfo:screen #0:
xdpyinfo: dimensions: 1280x768 pixels (339x203 millimeters)
xdpyinfo: resolution: 96x96 dots per inch
xdpyinfo: depths (7): 24, 1, 4, 8, 15, 16, 32
xdpyinfo: root window id: 0xe2
xdpyinfo: depth of root window: 24 planes
xdpyinfo: number of colormaps: minimum 1, maximum 1
xdpyinfo: default colormap: 0x20
xdpyinfo: default number of colormap cells: 256
xdpyinfo: preallocated pixels: black 0, white 16777215
xdpyinfo: options: backing-store WHEN MAPPED, save-unders NO
xdpyinfo: largest cursor: 64x64
xdpyinfo: current input event mask: 0xfac033
xdpyinfo: KeyPressMask KeyReleaseMask EnterWindowMask
xdpyinfo: LeaveWindowMask KeymapStateMask ExposureMask
xdpyinfo: StructureNotifyMask SubstructureNotifyMask SubstructureRedirectMask
xdpyinfo: FocusChangeMask PropertyChangeMask ColormapChangeMask
xdpyinfo: number of visuals: 64
xdpyinfo: default visual id: 0x21
xdpyinfo: visual:
xdpyinfo: visual id: 0x21
xdpyinfo: class: TrueColor
xdpyinfo: depth: 24 planes
xdpyinfo: available colormap entries: 256 per subfield
xdpyinfo: red, green, blue masks: 0xff0000, 0xff00, 0xff
xdpyinfo: significant bits in color specification: 8 bits
xdpyinfo: visual:
xdpyinfo: visual id: 0xa3
xdpyinfo: visual:
xdpyinfo: visual id: 0xa4
xdpyinfo: visual:
xdpyinfo: visual id: 0xa5
xdpyinfo: visual:
xdpyinfo: visual id: 0xa6
xdpyinfo: visual:
xdpyinfo: visual id: 0xa7
xdpyinfo: visual:
xdpyinfo: visual id: 0xa8
xdpyinfo: visual:
xdpyinfo: visual id: 0xa9
xdpyinfo: visual:
xdpyinfo: visual id: 0xaa
xdpyinfo: visual:
xdpyinfo: visual id: 0xab
xdpyinfo: visual:
xdpyinfo: visual id: 0xac
xdpyinfo: visual:
xdpyinfo: visual id: 0xad
xdpyinfo: visual:
xdpyinfo: visual id: 0xae
xdpyinfo: visual:
xdpyinfo: visual id: 0xaf
xdpyinfo: visual:
xdpyinfo: visual id: 0xb0
xdpyinfo: visual:
xdpyinfo: visual id: 0xb1
xdpyinfo: visual:
xdpyinfo: visual id: 0xb2
xdpyinfo: visual:
xdpyinfo: visual id: 0xb3
xdpyinfo: visual:
xdpyinfo: visual id: 0xb4
xdpyinfo: visual:
xdpyinfo: visual id: 0xb5
xdpyinfo: visual:
xdpyinfo: visual id: 0xb6
xdpyinfo: visual:
xdpyinfo: visual id: 0xb7
xdpyinfo: visual:
xdpyinfo: visual id: 0xb8
xdpyinfo: visual:
xdpyinfo: visual id: 0xb9
xdpyinfo: visual:
xdpyinfo: visual id: 0xba
xdpyinfo: visual:
xdpyinfo: visual id: 0xbb
xdpyinfo: visual:
xdpyinfo: visual id: 0xbc
xdpyinfo: visual:
xdpyinfo: visual id: 0xbd
xdpyinfo: visual:
xdpyinfo: visual id: 0xbe
xdpyinfo: visual:
xdpyinfo: visual id: 0xbf
xdpyinfo: visual:
xdpyinfo: visual id: 0xc0
xdpyinfo: visual:
xdpyinfo: visual id: 0xc1
xdpyinfo: class: DirectColor
xdpyinfo: visual:
xdpyinfo: visual id: 0xc2
xdpyinfo: visual:
xdpyinfo: visual id: 0xc3
xdpyinfo: visual:
xdpyinfo: visual id: 0xc4
xdpyinfo: visual:
xdpyinfo: visual id: 0xc5
xdpyinfo: visual:
xdpyinfo: visual id: 0xc6
xdpyinfo: visual:
xdpyinfo: visual id: 0xc7
xdpyinfo: visual:
xdpyinfo: visual id: 0xc8
xdpyinfo: visual:
xdpyinfo: visual id: 0xc9
xdpyinfo: visual:
xdpyinfo: visual id: 0xca
xdpyinfo: visual:
xdpyinfo: visual id: 0xcb
xdpyinfo: visual:
xdpyinfo: visual id: 0xcc
xdpyinfo: visual:
xdpyinfo: visual id: 0xcd
xdpyinfo: visual:
xdpyinfo: visual id: 0xce
xdpyinfo: visual:
xdpyinfo: visual id: 0xcf
xdpyinfo: visual:
xdpyinfo: visual id: 0xd0
xdpyinfo: visual:
xdpyinfo: visual id: 0xd1
xdpyinfo: visual:
xdpyinfo: visual id: 0xd2
xdpyinfo: visual:
xdpyinfo: visual id: 0xd3
xdpyinfo: visual:
xdpyinfo: visual id: 0xd4
xdpyinfo: visual:
xdpyinfo: visual id: 0xd5
xdpyinfo: visual:
xdpyinfo: visual id: 0xd6
xdpyinfo: visual:
xdpyinfo: visual id: 0xd7
xdpyinfo: visual:
xdpyinfo: visual id: 0xd8
xdpyinfo: visual:
xdpyinfo: visual id: 0xd9
xdpyinfo: visual:
xdpyinfo: visual id: 0xda
xdpyinfo: visual:
xdpyinfo: visual id: 0xdb
xdpyinfo: visual:
xdpyinfo: visual id: 0xdc
xdpyinfo: visual:
xdpyinfo: visual id: 0xdd
xdpyinfo: visual:
xdpyinfo: visual id: 0xde
xdpyinfo: visual:
xdpyinfo: visual id: 0xdf
xdpyinfo: visual:
xdpyinfo: visual id: 0xe0
xdpyinfo: visual:
xdpyinfo: visual id: 0x42
xdpyinfo: depth: 32 planes
sysconf:=====================================================================
sysconf:[Copyright 2002-2011] Cadence Design Systems, Inc. All rights reserved.
sysconf:This program and online documentation may not be copied, modified,
sysconf:re-published, uploaded, executed, or distributed in any way, in any
sysconf:medium, whether in whole or in part, without prior written permission
sysconf:from Cadence Design Systems, Inc.
sysconf:============== checkSysConf: Version 3.19 ====================
sysconf:Date information gathered: Fri Feb 13 21:18:40 PST 2015
sysconf:-------------------------------------------------------
sysconf:Host Name ..............: neil
sysconf:Hostid .................: 007f0100
sysconf:Operating System .......: Linux / x86_64
sysconf:OS Version .............: 6.0WS
sysconf:Kernel Version .........: 2.6.32-358.el6.x86_64
sysconf:Hardware Type ..........: x86_64
sysconf:Memory .................: 1862 Megabyte
sysconf:No. of CPUs ............: 2
sysconf:Total Swap Space........: 3999 Megabyte
sysconf:X Server ...............:
sysconf atch Data file ........: /home/neil/cadence/ic616/share/patchData/Linux/x86_64/redhat/6.0WS/IC6.1.6
sysconf:**************** Now verifying configuration ****************
sysconf:Validating Kernel requirements...
sysconf: Minimum Installed Status Info
sysconf: ------- --------- ------ --------------------
sysconf: 2.6.32-71 2.6.32-358.el6.x86_64PASS
sysconf:Validating MEMORY requirements MegaByte ...
sysconf: 1024MB 1862MB PASS
sysconf:Validating SWAP requirements in MegaByte ...
sysconf: 2048MB 3999MB PASS
sysconf:Validating DISPLAY requirements...
sysconf: --------- -------------------- ------ ----
sysconf: --- --- UNKNOWNRun script from console
sysconf:
sysconf:Validating PACKAGE requirements.....7 to check
sysconf:# PACKAGE Release Build Installed Status Info
sysconf:-- ------- ------- ----- --------- ------ --------------------
sysconf:1 glibc 2.12 1.7 2.12-1.149.el6_6.5.i686PASS
sysconf:-> 'GlibC'
sysconf:2 elfutils-libelf 0.148 1 0.158-3.2.el6.i686PASS
sysconf:-> 'Libelf Library'
sysconf:3 ksh 20100621 2 20120801-21.el6.1.x86_64PASS ksh is installed
sysconf:-> 'ksh'
sysconf:4 mesa-libGL 7.7 2 10.1.2-2.el6.i686PASS
sysconf:-> 'Mesa libGL Library'
sysconf:5 mesa-libGLU 7.7 2 10.1.2-2.el6.i686PASS
sysconf:-> 'Mesa libGLU Library'
sysconf:6 gdbm 1.8.0 36 1.8.0-36.el6.x86_64PASS
sysconf:-> 'libgdbm.so.2'
sysconf:7 glibc-devel 2.12 1.7 2.12-1.149.el6_6.5.i686PASS
sysconf:-> 'GlibC-devel'
sysconf:Validating FILE existence .....0 to check
sysconf:Validating NOTFILE existence .....0 to check
sysconf:Configuration checks failed on this workstation (neil), status is: FAIL
sysconf:To get DISPLAY info run the tool from Console.
sysconf:Exiting checkSysConf ... Good-bye
sysconf:Output is saved as /tmp/checkSysConf.neil-2015.02.13.21:18.3131.log
这个是错误的log,不知道从哪里能看出来是什么错误 |
