查看: 12767|回复: 48
[资料] Asymmetric Passive Components in Microwave Integrated Circuits
发表于 2014-7-22 14:11:54 | 显示全部楼层 |阅读模式
作者简介HEE-RAN AHN, PhD, is a member of the Department of Electronics and Electrical Engineering at Pohang University of Science and Technology (POSTECH), Korea. Dr. Ahn is internationally recognized as a leader and innovator in asymmetric passive components such as ring and branch-line hybrids, power dividers, phase shifters, attenuators, and impedance transformers (CVTs and CCTs).
目录Preface. 1. Introduction. 1.1 Asymmetric Passive Components. 1.2 Circuit Parameters. 1.3 Asymmetric Four-Port Hybrids. 1.4 Asymmetric Three-Port Power Dividers. 1.5 Asymmetric Two-Port Components. References. 2. Circuit Parameters. 2.1 Scattering Matrix. 2.2 Scattering Parameters of Reduced Multiports. 2.3 Two-Port Network Analysis Using Scattering Parameters. 2.4 Other Circuit Parameters. 2.5 Analyses of Symmetric Networks. 2.6 Analyses with Image Parameters. Exercises. References. 3. Conventional Ring Hybrids. 3.1 Introduction. 3.2 Original Concept of the 3-dB Ring Hybrid. 3.3 Conventional Ring Hybrids. 3.4 Conventional 3-dB Uniplanar Ring Hybrids. Exercises. References. 4. Asymmetric Ring Hybrids. 4.1 Introduction. 4.2 Derivation of Design Equations of Asymmetric Ring Hybrids. 4.3 Small Asymmetric Ring Hybrids. 4.4 Wideband or Small Asymmetric Ring Hybrids. 4.5 Miniaturized Ring Hybrids Terminated in Arbitrary Impedances. Exercises. References. 5. Asymmetric Branch-Line Hybrids. 5.1 Introduction. 5.2 Origin of Branch-Line Hybrids. 5.3 Multisection Branch-Line Couplers. 5.4 Branch-Line Hybrids for Impedance Transforming. 5.5 Asymmetric Four-Port Hybrids. Exercises. References. 6. Conventional Three-Port Power Dividers. 6.1 Introduction. 6.2 Three-Port 3-dB Power Dividers. 6.3 Three-Port Power Dividers with Arbitrary Power Divisions. 6.4 Symmetric Analyses of Asymmetric Three-Port Power Dividers. 6.5 Three-Port 3-dB Power Dividers Terminated in Complex Frequency-Dependent Impedances. 6.6 Three-Port 45 Power Divider/Combiner. Exercises. References. 7. Three-Port 3-dB Power Dividers Terminated in Different Impedances. 7.1 Introduction. 7.2 Perfect Isolation Condition. 7.3 Analyses. 7.4 Scattering Parameters of Three-Port Power Dividers. 7.5 Lumped-Element Three-Port 3-dB Power Dividers. 7.6 Coplanar Three-Port 3-dB Power Dividers. Exercises. References. 8. General Design Equations for N-Way Arbitrary Power Dividers. 8.1 Introduction. 8.2 General Design Equations for Three-Port Power Dividers. 8.3 General Design Equations for N-Way Power Dividers. Exercises. References. 9. Asymmetric Ring-Hybrid Phase Shifters and Attenuators. 9.1 Introduction. 9.2 Scattering Parameters of Asymmetric Ring Hybrids. 9.3 Asymmetric Ring-Hybrid Phase Shifters. 9.4 Asymmetric Ring-Hybrid Attenuator with Phase Shifts. Exercises. References. 10. Ring Filters and Their Use in a New Measurement Technique for Inherent Ring-Resonance Frequency. 10.1 Introduction. 10.2 Ring Filters. 10.3 New Measurement Technique for Inherent Ring-Resonance Frequency. 10.4 Conclusions. Exercises. References. 11. Small Impedance Transformers, CVTs and CCTs, and Their Applications to Small Power Dividers and Ring Filters. 11.1 Small Transmission-Line Impedance Transformers. 11.2 Mathematical Approach for CVTs and CCTs. 11.3 CVT3PDs and CCT3PDs. 11.4 Asymmetric Three-Port 45 Power Divider Terminated in Arbitrary Impedances. 11.5 CVT and CCT Ring Filters. 11.5.1 Analyses of Ring Filters. Exercises. References. Appendix A: Symbols and Abbreviations. Appendix B: Conversion Matrices. Appendix C: Derivation of the Elements of a Small Asymmetric Ring Hybrid. Appendix D: Trigonometric Relations. Appendix E: Hyperbolic Relations. Index.
Asymmetric Passive Components in Microwave Integrated Circuits.pdf
5.9 MB, 下载次数: 339 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2014-7-22 20:43:25 | 显示全部楼层
passive
发表于 2014-7-23 08:54:43 | 显示全部楼层
谢谢楼主分享,如果有校准电路方面的文章就更好了
发表于 2014-7-23 09:48:56 | 显示全部楼层
CST.Studio.Suite.2014
 楼主| 发表于 2014-7-23 18:02:15 | 显示全部楼层
回复 3# water422
你说的校准是指什么校准?你研究的方向是什么呀?
发表于 2014-7-27 17:17:21 | 显示全部楼层
这么好的教材看看!!!
发表于 2014-7-27 18:41:26 | 显示全部楼层
这么好的教材看看!!!
发表于 2014-7-27 18:47:32 | 显示全部楼层
发表于 2014-7-27 18:52:21 | 显示全部楼层
这么好的教材看看!!!
发表于 2014-7-27 19:47:07 | 显示全部楼层
这么好的教材看看!!!
GMT+8, 2025-11-7 06:18 , Processed in 0.023372 second(s), 4 queries , Gzip On, Redis On.
