查看: 4583|回复: 7
[求助] 关于insertion dealy的纠结。
发表于 2014-4-28 17:06:21 | 显示全部楼层 |阅读模式
今天做到CTS这一步,goals of CTS 其中之一就是min insertion delay。
不太懂insertion delay的意思,便去查阅了User Guide,上面是这么写的:
Source latency, also known as insertion delay, is the time it takes for a clock to be propagated from its ideal waveform origin point to the clock definition point in the design
然后在论坛上查了下,有人是这样解释:
Insertion delay是指clock root pin和flip flop的clock sink pin之间的延时。
这两句话明显不是一个意思,有没有很懂的行内人帮我确定下哪个是对的,并说说自己的看法呢.
 楼主| 发表于 2014-4-28 17:12:09 | 显示全部楼层
发现点东西。
During clock tree synthesis, the tool considers only the clock tree timing goals. It does not
consider the latency (as specified by the set_clock_latency command) or uncertainty (as
specified by the set_clock_uncertainty command).
是不是CTS的insertion delay和set_clock_latency指定的insertion delay不同,所以产生了问题中两者的差别?
发表于 2014-4-28 19:28:53 | 显示全部楼层
回复 1# lb_Mvp
    请问是哪个User guide?
    一般 insertion dealay 指的是 network latency.
 楼主| 发表于 2014-4-28 20:26:16 | 显示全部楼层
回复 3# zero_0
    eetop.cn_Timing Constraints and Opt user guide.pdf (2.33 MB , 下载次数: 98 )
就是这个,你可以看看。里面讲得insertion delay和network delay是两个不同的概念,它们合起来组成了total latency
发表于 2014-4-28 22:16:49 | 显示全部楼层
静等大神解答
 楼主| 发表于 2014-4-30 10:50:47 | 显示全部楼层
回复 5# lunluoren8
   大神不来额。。
发表于 2017-6-7 17:59:56 | 显示全部楼层
回复 6# lb_Mvp
    上面说的很清楚啊,insertion delay know as source latency. 是PLL到 definition clock point的。network delay 是definition point 到DFF CK pin
发表于 2023-10-20 16:43:08 | 显示全部楼层
搜了一下,发现c家的定义是insertion delay对应clock latency,里面又包括source latency和network latency;s家定义是insertion delay对应source latency
头晕……
我感觉是c家的insertion delay对应clock latency,source latency对应source insertion delay,network latency对应network
insertion delay
GMT+8, 2025-12-19 01:09 , Processed in 0.023669 second(s), 8 queries , Gzip On, Redis On.
