楼主: VisionSim
[原创] 终于把AMS摸透了,过程可怜的,发个总结庆祝一下
发表于 2014-4-2 22:17:14 | 显示全部楼层
回复 1# tangyaoyun
     我拷贝了connect_Lib到仿真当前目录,并且设置了DEFINE connectLib ./connect_Lib/connectLib
       在ADE中也选择了ams仿真工具,而且也进行了connect Lib的设置,仿真的时候总是报No connection rule的问题,LZ有遇到过吗
       ncelab: *E,CUVNCM (./ihnl/li/mixsim/schematic/verilog.vams,20|68): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance mixsim.I6.
发表于 2014-4-2 23:12:34 | 显示全部楼层
感謝 ~~~
发表于 2014-4-3 00:54:45 | 显示全部楼层
多谢楼主,学习下。
 楼主| 发表于 2014-4-3 10:39:47 | 显示全部楼层
回复 21# abcc123
你设置好connet rule 了吗??
发表于 2014-4-3 11:05:55 | 显示全部楼层
回复 24# tangyaoyun
    在ADE的setup->connect rule..选择了User-defined(ncvlog,ncelab,ncsim),add了library,cell,view到list of Connect Rules Used in Simulation,可是仿真的时候还是出现No connect rules found的问题
// 'ConnRules_35V.vams' - Verilog-AMS 3.5 volt connection rules file.
// last revised:  10/22/02 (ronv)
// This file is a template for definition of rules for a particular
// logic family.  Values for some typical parameters are defined here,
// then used in the three sets of connections rules below.
// See the "README.txt" file for a more complete usage description.
`define Vsup  4.5
`define Vthi  1.8
`define Vtlo  0.8
`define Tr    0.2n
`define Rlo   200
`define Rhi   200
`define Rx    40
`define Rz    10M
connectrules ConnRules_35V_mid;
  connect E2L #( .vsup(`Vsup), .vthi(`Vthi), .vtlo(`Vtlo), .tr(`Tr) );
  connect L2E_1 #( .vsup(`Vsup), .tr(`Tr), .rout(`Rlo) );
  connect Bidir_0 #( .vsup(`Vsup), .vthi(`Vthi), .vtlo(`Vtlo),
endconnectrules
发表于 2014-4-3 11:07:43 | 显示全部楼层
回复 24# tangyaoyun
    加了connect rule还是不行啊,LZ
发表于 2014-4-3 11:09:12 | 显示全部楼层
回复 24# tangyaoyun
    在ADE的setup->connect rules加的这个rule,还是不行
    // 'ConnRules_35V.vams' - Verilog-AMS 1.8 volt connection rules file.
`define Vsup  4.5
`define Vthi  1.8
`define Vtlo  0.8
`define Tr    0.2n
`define Rlo   200
`define Rhi   200
`define Rx    40
`define Rz    10M
endconnectrules
 楼主| 发表于 2014-4-3 12:53:01 | 显示全部楼层
回复 27# abcc123
能调用connect rule说明你cds.lib的设置是对的,你调用的是3.5V的rule,你所用的工艺是这个电压吗??
发表于 2014-4-3 13:17:30 | 显示全部楼层
回复 28# tangyaoyun
       工艺是5V的模拟工艺器件,但是整个系统供电采用锂电池,仿真时设置为3.5V
 楼主| 发表于 2014-4-3 17:40:52 | 显示全部楼层
回复 26# abcc123
什么问题?
GMT+8, 2025-11-5 04:05 , Processed in 0.021530 second(s), 3 queries , Gzip On, Redis On.
