在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 1655|回复: 0
[求助] Library unit config is not available in Liarary
发表于 2013-12-23 07:04:29 | 显示全部楼层 |阅读模式
When I use the leon3 IP ,after I have done synthesized on ISE,there is a error:"Library unit config is not available in Liarary."  So I go to the lib file ,find out the there is no a file called config in lib,should I create a file called config?And anyother should I do correctly?Thank you a lot.
GMT+8, 2024-4-26 16:04 , Processed in 0.022468 second(s), 9 queries , Gzip On, Redis On.
