查看: 6854|回复: 10
How to Run MVTool Example???
发表于 2013-5-14 07:08:22 | 显示全部楼层 |阅读模式
When I Run MVtool Example, I have followed these steps below:
(1)#csh (change bash to csh)
(2)#source setup.csh
(3)#make all
but I have Got the Error:
[MVCMP] FATAL 547: Couldn't open file: '/powerspec/ocpfsm.upf'.
[MVCMP] FATAL 4008: Critical error(s) found. See previous error for details.
Nice guys, please give me some tips, How can I run The MVTool example?
Thanks!
发表于 2013-5-14 09:06:33 | 显示全部楼层
Maybe your environment variable setting "TEST_ROOT" is not successful, maybe you started from the wrong directory. You should start from the parent level of run_mvsim directory, or set the env variable in the .bashrc file.
now I'm facing another problem, the MVDBGEN step complains that I need to apply connect_supply_net command to connect the primary power pins to the LS/ELS cells in a ARCH_PGConn.upf file, but I don't know how to do it.
 楼主| 发表于 2013-5-14 11:16:01 | 显示全部楼层
回复 2# fengsui
    Now I have the same problem as yours too!
 楼主| 发表于 2013-5-20 15:06:27 | 显示全部楼层
回复 2# fengsui
    [MVDBGEN] ERROR 3658: Connect_supply_net UPF command missing for 'Primary power pins'pins of 'LS/ELS Cells'. See file 'ARCH_PGConn.upf' for explicit PG connections expected in UPF.
请问这个问题怎么解决的???
发表于 2013-6-6 07:49:24 | 显示全部楼层
回复 4# 飞扬紫百合
   后来没有进行下去了,你那边有什么进展吗
 楼主| 发表于 2013-6-6 12:24:04 | 显示全部楼层
回复 5# fengsui
    没有继续,但是单位里的低版本跑起来没问题,难道是版本问题?系统问题?还是license问题?
搞不清楚!
 楼主| 发表于 2013-6-6 12:29:45 | 显示全部楼层
回复 5# fengsui
    要不你换个低版本试试
发表于 2013-8-5 17:21:37 | 显示全部楼层
回复 3# 飞扬紫百合
打开$your_path/examples/mvsim_mvrc_demo_eg/rtl/dmaIsoWrapper.v这个文件,这个文件是关于isolation cell map操作的,里面有各种错误的mapped,是故意这么写的,以便初学者分析。要消除[MVDBGEN] ERROR 3658: 只需修改54行 ELSHL_AND改成ISO_AND即可。
 楼主| 发表于 2013-8-8 11:05:39 | 显示全部楼层
回复 10# 轻水一杯
Thanks!
I'll Try Again!
发表于 2014-1-6 14:08:29 | 显示全部楼层
这么做后,[MVDBGEN] ERROR 3658: Connect_supply_net UPF command missing for 'Primary power pins'pins of 'LS/ELS Cells'. 这个问题解决了。但是仍然有问题。
[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.DmaPwrGood corresponding to Isolation Policy 'VDMA_domain/dma_iso_and' changed to invalid value = Z at time = 1 ps.[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.MemPwrGood corresponding to Isolation Policy 'VMEM_domain/mem_iso_and' changed to invalid value = Z at time = 1 ps.[MVSIM] INFO 5131: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value Z at time = 1 ps.[MVSIM] ERROR 5503: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1 ps.[MVSIM] INFO 5129: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value Z at time = 1 ps.[MVSIM] ERROR 5502: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1 ps.[MVSIM] INFO 5005: In Power State Table ocpPst Simulation started with design in OFF state[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.DmaPwrGood corresponding to Isolation Policy 'VDMA_domain/dma_iso_and' changed to invalid value = X at time = 1000 ps.[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.MemPwrGood corresponding to Isolation Policy 'VMEM_domain/mem_iso_and' changed to invalid value = X at time = 1000 ps.[MVSIM] INFO 5131: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value X at time = 1000 ps.[MVSIM] ERROR 5503: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1000 ps.[MVSIM] INFO 5129: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value X at time = 1000 ps.[MVSIM] ERROR 5502: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1000 ps.
LZ有碰到吗,怎么解决的呢?我试了mvtools2012.09+vcs2012.09
GMT+8, 2025-12-23 12:16 , Processed in 0.023453 second(s), 4 queries , Gzip On, Redis On.
