楼主: 飞扬紫百合
How to Run MVTool Example???
 楼主| 发表于 2013-8-8 11:05:39 | 显示全部楼层
回复 10# 轻水一杯
Thanks!
I'll Try Again!
发表于 2014-1-6 14:08:29 | 显示全部楼层
这么做后,[MVDBGEN] ERROR 3658: Connect_supply_net UPF command missing for 'Primary power pins'pins of 'LS/ELS Cells'. 这个问题解决了。但是仍然有问题。
[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.DmaPwrGood corresponding to Isolation Policy 'VDMA_domain/dma_iso_and' changed to invalid value = Z at time = 1 ps.[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.MemPwrGood corresponding to Isolation Policy 'VMEM_domain/mem_iso_and' changed to invalid value = Z at time = 1 ps.[MVSIM] INFO 5131: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value Z at time = 1 ps.[MVSIM] ERROR 5503: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1 ps.[MVSIM] INFO 5129: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value Z at time = 1 ps.[MVSIM] ERROR 5502: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1 ps.[MVSIM] INFO 5005: In Power State Table ocpPst Simulation started with design in OFF state[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.DmaPwrGood corresponding to Isolation Policy 'VDMA_domain/dma_iso_and' changed to invalid value = X at time = 1000 ps.[MVSIM] ERROR 5406: Isolation Enable signal ocp_top.MemPwrGood corresponding to Isolation Policy 'VMEM_domain/mem_iso_and' changed to invalid value = X at time = 1000 ps.[MVSIM] INFO 5131: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value X at time = 1000 ps.[MVSIM] ERROR 5503: Restore signal ocp_top.RestoreDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1000 ps.[MVSIM] INFO 5129: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to value X at time = 1000 ps.[MVSIM] ERROR 5502: Save signal ocp_top.SaveDma corresponding to Retention Policy 'VDMA_domain/DMACFG' changed to invalid value at time = 1000 ps.
LZ有碰到吗,怎么解决的呢?我试了mvtools2012.09+vcs2012.09
发表于 2018-4-9 10:40:43 | 显示全部楼层
回复 12# hazzm02
    http://bbs.eetop.cn/thread-433570-1-1.html
详细见这个帖子
GMT+8, 2025-12-27 11:05 , Processed in 0.012629 second(s), 3 queries , Gzip On, Redis On.
