查看: 4776|回复: 10
[资料] [连接Vivado和Matlab的全自动化操作]
发表于 2013-3-31 08:54:43 | 显示全部楼层 |阅读模式
[An automatic signal post-analysis widget between Vivado and Matlab]
The Debugger (just like ChipScope in ISE) in Vivado has capability to capture data in real hardware. One can use this capability to visualize the signal in debugger window. But at present, Xilinx hasn't released any routine that can connect Debugger with 3rd party software such as MATLAB for post-analysis.
So I did this for Xilinx, and one can use this widget to automatically extract real data from hardware, and automatically analyze it by MATLAB in any way.
Vivado套件中的Debugger(类似ISE套件中的ChipScope)提供了在本地窗口中查看硬件实时数据的途径。但是至今为止Xilinx还没有提供该调试工具和第三方的接口,因此如果要使用诸如MATLAB之类的工具来分析数据则十分不便。
基于上述原因,偶设计了这个接口,可以使用MATLAB来任意地分析后期数据,而且所有的过程都是自动化的,不需要任何人工的操作。
Get the video from here, and you can pay for this if you like~ ;- )
http://pan.baidu.com/share/link?shareid=524378&uk=923937718
发表于 2013-4-3 17:55:32 | 显示全部楼层
又学习了一点。呵呵
发表于 2013-4-6 22:17:46 | 显示全部楼层
升起来了
发表于 2013-4-12 15:26:53 | 显示全部楼层
ZHICHIZHICHI
发表于 2013-10-29 10:53:24 | 显示全部楼层
Thank you
发表于 2013-12-11 00:58:58 | 显示全部楼层
VERY NICE TIPS FOR TRAINNING
发表于 2013-12-15 18:39:53 | 显示全部楼层
好东西,强人
发表于 2013-12-25 20:52:46 | 显示全部楼层
发表于 2013-12-31 15:38:25 | 显示全部楼层
分享被取消
 楼主| 发表于 2014-1-18 15:04:29 | 显示全部楼层
回复 8# jlqsczw_2007
    http://pan.baidu.com/s/1w4pjg
GMT+8, 2025-12-17 03:13 , Processed in 0.020755 second(s), 6 queries , Gzip On, Redis On.
