查看: 19282|回复: 15
[求助] 求助,VCS在ubuntu 64位的问题
发表于 2013-2-26 09:12:32 | 显示全部楼层 |阅读模式
我在ubuntu 10.04LTS里面安装了VCS,启动VCS和DVE都可以,我编译verilog文件的时候出现如下错误。
我有两个文件,count.v 和count_tb.v,使用vcs count_tb.v count.v执行有问题。log如下:
/usr/synopsys/D-2010.06-4/bin/vcsMsgReport: line 332: /bin/basename: 没有那个文件或目录
Warning-[LNX_OS_VERUN] Unsupported Linux version
  Linux version '' is not supported on 'x86_64' officially, assuming linux
  compatibility by default. Set VCS_ARCH_OVERRIDE to linux or suse32 to
  override.
  Please refer to release notes for information on supported platforms.
                         Chronologic VCS (TM)
           Version D-2010.06-4 -- Tue Feb 26 09:12:27 2013
               Copyright (c) 1991-2010 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
9:12:27 (snpslmd) OUT: "VCSCompiler_Net" root@ubuntu
Parsing design file 'count_tb.v'
Parsing design file 'count.v'
Top Level Modules:
       count_tb
TimeScale is 1 ns / 1 ns
Warning-[PALF] Potential always loop found
count_tb.v, 20
  This always block has no event control or delay statements, it might cause
  an infinite loop in simulation.
Starting vcs inline pass...
2 modules and 0 UDP read.
        However, due to incremental compilation, no re-compilation is necessary.
9:12:28 (snpslmd) IN: "VCSCompiler_Net" root@ubuntu
if [ -x ../simv ]; then chmod -x ../simv; fi
g++  -o ../simv -melf_i386 -m32    SIM_l.o 5NrI_d.o 5NrIB_d.o    pre_vcsobj_1_1.o  rmapats_mop.o rmapats.o       /usr/synopsys/D-2010.06-4/linux/lib/libvirsim.so /usr/synopsys/D-2010.06-4/linux/lib/librterrorinf.so /usr/synopsys/D-2010.06-4/linux/lib/libsnpsmalloc.so     /usr/synopsys/D-2010.06-4/linux/lib/libvcsnew.so        /usr/synopsys/D-2010.06-4/linux/lib/vcs_save_restore_new.o /usr/synopsys/D-2010.06-4/linux/lib/ctype-stubs_32.a -ldl  -lc -lm -lpthread -ldl
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../libdl.so when searching for -ldl
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../libdl.a when searching for -ldl
/usr/bin/ld: skipping incompatible /usr/lib/libdl.so when searching for -ldl
/usr/bin/ld: skipping incompatible /usr/lib/libdl.a when searching for -ldl
/usr/bin/ld: cannot find -ldl
collect2: ld returned 1 exit status
make: *** [product_timestamp] 错误 1
Make exited with status 2
CPU time: .220 seconds to compile + .100 seconds to elab + .180 seconds to link
我加上-full64参数之后,出现另外一个错误,log如下:
  override.
        Version D-2010.06-4_Full64 -- Tue Feb 26 09:14:03 2013
                         ALL RIGHTS RESERVED
9:14:03 (snpslmd) OUT: "VCSCompiler_Net" root@ubuntu
Top Level Modules:
       count_tb
count_tb.v, 20
recompiling module count_tb
Both modules done.
9:14:04 (snpslmd) IN: "VCSCompiler_Net" root@ubuntu
g++  -o ../simv   _vcsobj_1_1.o  5NrI_d.o 5NrIB_d.o SIM_l.o     rmapats_mop.o rmapats.o       /usr/synopsys/D-2010.06-4/amd64/lib/libvirsim.so /usr/synopsys/D-2010.06-4/amd64/lib/liberrorinf.so /usr/synopsys/D-2010.06-4/amd64/lib/libsnpsmalloc.so     /usr/synopsys/D-2010.06-4/amd64/lib/libvcsnew.so        /usr/synopsys/D-2010.06-4/amd64/lib/vcs_save_restore_new.o -ldl  -lc -lm -lpthread -ldl
/usr/bin/ld: i386 architecture of input file `rmapats_mop.o' is incompatible with i386:x86-64 output
CPU time: .230 seconds to compile + .070 seconds to elab + .280 seconds to link
在线求助,感激不尽。
 楼主| 发表于 2013-2-26 09:39:57 | 显示全部楼层
这个错误可以通过安装g++-multilib解决,但是连接还是有第二个错误,怎么解决呢,log如下:
  override.
           Version D-2010.06-4 -- Tue Feb 26 09:43:44 2013
                         ALL RIGHTS RESERVED
9:43:44 (snpslmd) OUT: "VCSCompiler_Net" root@ubuntu
Top Level Modules:
       count_tb
count_tb.v, 20
recompiling module count_tb because:
        Generated file (F6R9_1) not found, or not incremental.
recompiling module count because:
        Generated file (r07N_1) not found, or not incremental.
Both modules done.
9:43:44 (snpslmd) IN: "VCSCompiler_Net" root@ubuntu
g++  -o ../simv -melf_i386 -m32   _vcsobj_1_1.o  5NrI_d.o 5NrIB_d.o SIM_l.o     rmapats_mop.o rmapats.o       /usr/synopsys/D-2010.06-4/linux/lib/libvirsim.so /usr/synopsys/D-2010.06-4/linux/lib/librterrorinf.so /usr/synopsys/D-2010.06-4/linux/lib/libsnpsmalloc.so     /usr/synopsys/D-2010.06-4/linux/lib/libvcsnew.so        /usr/synopsys/D-2010.06-4/linux/lib/vcs_save_restore_new.o /usr/synopsys/D-2010.06-4/linux/lib/ctype-stubs_32.a -ldl  -lc -lm -lpthread -ldl
/usr/bin/ld: i386:x86-64 architecture of input file `rmapats.o' is incompatible with i386 output
/usr/bin/ld: final link failed: Invalid operation
 楼主| 发表于 2013-2-26 10:16:46 | 显示全部楼层
问题已经解决,哎整了将近两天啊。。。
解决方法如下:
执行编译命令,遇到这个问题后,在当前目录下会有一个csrc目录,进入这个目录,发现有个Makefile,用gedit打开,将下面字段
# Override TARGET_ARCH
TARGET_ARCH=
修改为:
TARGET_ARCH=x86-64
并且删除*.o,rm *.o,然后再执行make,重新生成rmapats.o文件,这次生成的就对了。。。
这也是一种临时解决办法,真是折腾啊。。。
使用vcs -full64 x.v 仍然存在问题,采用类似方法会出现段错误,64位使用不了。只能使用32位的了。
= 后来64位的采样类似的方法处理之后也可以,无语啊无语!!!方法如下:
正如上面所述,会遇到段错误,此时将csrc目录删除,rm -r csrc,然后执行下面命令:
vcs -full64 -m64 xx00.v xx01.v xx02.v
正确生成simv文件,模拟正确。
另外:我在安装comon的时候,安装到最后出现过错误,被我忽略了,不知道有没有后遗症。
根据目标目录下的instll.log可以分析,暂且不管!
回复 支持 0 反对 1
发表于 2013-2-26 13:40:15 | 显示全部楼层
回复 3# chen.terry
   高手啊高手
发表于 2013-4-3 10:03:02 | 显示全部楼层
不错啊,刚好碰到这个问题
发表于 2013-4-3 15:24:08 | 显示全部楼层
我的错是“/usr/bin/ld: i386:x86-64 architecture of input file `/usr/lib/x86_64-linux-gnu/crti.o' is incompatible with i386 output”
这个怎么搞定?我原来跑得好好的,都不知道装那个东西搞烂的 T_T
发表于 2013-4-6 13:12:11 | 显示全部楼层
跟Linux没啥关系吧
发表于 2013-4-7 23:31:35 | 显示全部楼层
good man
发表于 2013-4-9 17:00:31 | 显示全部楼层
应该是前后两次编译的版本之类的有问题吧?
发表于 2013-9-4 17:27:51 | 显示全部楼层
我也遇到同樣的問題,依照樓主的解法已經解決了,
最後我是用 vcs -full64 -m64 xxx.v 解決的,
感謝樓主
GMT+8, 2025-12-24 07:37 , Processed in 0.025272 second(s), 5 queries , Gzip On, Redis On.
