查看: 6966|回复: 7
[求助] Unused Pins 的几种设置
发表于 2012-9-26 15:14:42 | 显示全部楼层 |阅读模式
Quartus II中unused pins的几种设置有什么区别么?我每次都是用As input tri-stated……
    As input tri-statedThe pins are reserved as tri-state input pins.
    As output driving groundThe pins are reserved as output pins and drive the ground signal.
    As output driving an unspecified signal—The pins are reserved as output pins and drive any signal.
    As input tri-stated with bus-hold circuitryThe pins are reserved as tri-state input pins with bus-hold circuitry.
    As input tri-stated with weak pull-up resistorThe pins are reserved as tri-state input pins with weak pull-up resistors.
发表于 2012-9-26 19:57:50 | 显示全部楼层
帮忙顶一下,新手飘过
发表于 2012-9-26 23:22:49 | 显示全部楼层
我觉得还是tri-state比较好
发表于 2012-10-27 02:50:09 | 显示全部楼层
现在高版本的quartus默认都是最后一种了
反正不能用driving ground,片子烫死了,哈哈
发表于 2012-10-27 09:37:10 | 显示全部楼层
As input tri-stated耗电大,还是弱上拉或弱保持好。
发表于 2012-10-27 15:49:59 | 显示全部楼层
哪位能不能明确的给讲解一下这几种具体是什么样的?
 楼主| 发表于 2012-10-29 20:11:12 | 显示全部楼层
这几天忙得也没顾得上论坛了~~谢谢楼上大神们的回复啊!
发表于 2012-10-29 20:30:42 | 显示全部楼层
使用as input trigate ,仅知道使用as output driven groud 片子非常热。
GMT+8, 2025-11-8 16:51 , Processed in 0.020471 second(s), 7 queries , Gzip On, Redis On.
