在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2787|回复: 3
[求助] agent中undefined variable
发表于 2012-6-1 10:58:31 | 显示全部楼层 |阅读模式
我写的agent提示:# QuestaSim vlog 10.0d Compiler 2011.10 Oct 30 2011
# ** Note: (vlog-2286) Using implicit +incdir+E:/questasim_10.0d/uvm-1.1/../verilog_src/uvm-1.1/src from import uvm_pkg
# ** Error: booth_agent.sv(36): Undefined variable: sqr.
# ** Error: booth_agent.sv(37): Undefined variable: drv.
# ** Error: booth_agent.sv(41): Undefined variable: mon.
附agent的代码:
`include "uvm_macros.svh"
`include "booth_monitor.sv"
`include "booth_driver.sv"
`include "booth_sequencer.sv"
import uvm_pkg::*;
class booth_agent extends uvm_agent;
  uvm_active_passive_enum is_active = UVM_ACTIVE;
  booth_sequencer sqr;
  booth_driver drv;
  booth_monitor mon;
  uvm_analysis_port #( booth_frame ) agent_from_drv_mon;
  function new( string name , uvm_component parent );
super.name( name , parent );
endfunction
  extern virtual function void build_phase( uvm_phase phase );
  extern virtual function void connect_phase( uvm_phase phase );
  `uvm_component_utils_begin( booth_agent )
    `uvm_field_enum( uvm_active_passive_enum , is_active , UVM_ALL_ON);
//    `uvm_field_object( sqr , UVM_DEFAULT )
//    `uvm_field_object( drv , UVM_ALL_ON )
//    `uvm_field_object( mon , UVM_ALL_ON )
  `uvm_component_utils_end
endclass
  super.build_phase( phase );
//  if( is_active == UVM_ACTIVE ) begin
    sqr = booth_sequencer::type_id::create("sqr",this);
    drv = booth_driver::type_id::create("drv",this);
    `uvm_info("Create","Agent have created sqr and drv.",UVM_LOW)
//  end
//  else begin
    mon = booth_monitor::type_id::create("mon",this);
//  end
endfunction
function void booth_agent::connect_phase( uvm_phase phase );
  super.connect_phase( phase );
    this.agent_from_drv_mon = drv.driver_to_agent;
    drv.seq_item_port.connect(sqr.seq_item_export);
  end
  else begin
    this.agent_from_drv_mon = mon.monitor_to_agent;
  end
endfunction
`endif
 楼主| 发表于 2012-6-1 13:56:18 | 显示全部楼层
回复 2# 海天之间
   这里我是用的tab,粘贴过程中排版问题吧?
发表于 2012-6-2 11:19:07 | 显示全部楼层
请检查一下 仿真工具的编译的log里面  是否在报这个错误之前 已经将这几个文件编译过了
 楼主| 发表于 2012-6-4 10:01:08 | 显示全部楼层
回复 3# feiying_cq
   是我写错了。new中的super.new写错了。
GMT+8, 2024-5-2 06:06 , Processed in 0.041456 second(s), 9 queries , Gzip On, Redis On.
