查看: 38218|回复: 49
Mathworks Matlab 2012a win32/64 + Crack (115網盤)
发表于 2012-4-5 01:03:39 | 显示全部楼层 |阅读模式
MATLAB is a programming environment for algorithm development, data analysis, visualization, and numerical computation. Using MATLAB, you can solve technical computing problems faster than with traditional programming languages, such as C, C++, and Fortran
You can use MATLAB in a wide range of applications, including signal and image processing, communications, control design, test and measurement, financial modeling and analysis, and computational biology. For a million engineers and scientists in industry and academia, MATLAB is the language of technical computing
有人反映說檔案下載後有問題但原分割檔已刪除
所以重新傳一份到115
請有需要的人重新抓取
Mathworks.Matlab.R2012a.part1.rar
http://115.com/file/be5ghi4e#/
Mathworks.Matlab.R2012a.part2.rar
http://115.com/file/dpcmnmz6#/
Mathworks.Matlab.R2012a.part3.rar
http://115.com/file/be5geam8#/
Mathworks.Matlab.R2012a.part4.rar
http://115.com/file/an3uuxwz#/
Mathworks.Matlab.R2012a.part5.rar
http://115.com/file/e7ut7tco#/
PW.zip (163 Bytes , 下载次数: 218 )
发表于 2012-4-11 18:04:25 | 显示全部楼层
少两个啊。。。。
 楼主| 发表于 2012-4-11 18:28:26 | 显示全部楼层
我剛剛檢查...是306個沒錯阿
請問一下是少哪兩個?
发表于 2012-4-11 22:36:04 | 显示全部楼层
这个压缩包也太多了,电驴上就有,大家还是去电驴下载比较方便~~
发表于 2012-4-11 22:36:51 | 显示全部楼层
发表于 2012-4-11 22:41:15 | 显示全部楼层
电驴的下载地址为:
windows版本: [科学计算语言].TLF-SOFT-Mathworks.Matlab.R2012a.ISO-TBE.iso (4.47 GB)
Unix版本:
[科学计算语言].TLF-SOFT-Mathworks.Matlab.R2012a.UNIX.ISO-TBE.iso (4.97 GB)
发表于 2012-4-11 22:42:01 | 显示全部楼层
电驴的下载地址为:
Unix版本:
发表于 2012-4-11 22:42:48 | 显示全部楼层
电驴的下载地址为:
Unix版本:
发表于 2012-4-13 10:09:34 | 显示全部楼层
压缩包是挺多的,没那么多米啊
发表于 2012-5-14 10:11:35 | 显示全部楼层
顶一个,慢慢下。
GMT+8, 2025-12-25 10:30 , Processed in 0.023579 second(s), 6 queries , Gzip On, Redis On.
