查看: 7302|回复: 3
[求助] stream out gds through icfb
发表于 2011-12-12 21:31:00 | 显示全部楼层 |阅读模式
Hi, all
before my submitting the final GDS(.5um) this weekend, I wanna confirm the exporting procedure  again.
1.in ICC using the following scripts to export the gds:
set_write_stream_options -reset
set_write_stream_options \
  -map_layer  gds2OutLayer.map \
  -child_depth 0 \
  -output_filling {fill} \
  -output_outdated_fill \
  -keep_data_type \
  -output_geometry_property \
  -output_pin {geometry} \
  -output_polygon_pin
2.then using icfb to merge the gds
  a.stream in the IO-pad gds
  b.stream in the core gds
  c.stream the top-cell gds,  setting the following option in this step
  d.export the final GDS, setting the following option in this step
other options are default.
Is what's presented above okay? or any further adjustment?
thanks in advance
best regards,
henry
发表于 2011-12-13 15:27:23 | 显示全部楼层
2的次序是先c吧
 楼主| 发表于 2011-12-13 22:21:14 | 显示全部楼层
回复 2# damonzhao
   多谢关注哈.
2中的顺序应该是那样的.
c,d两步中的option没显示了来,
c中选中(Retain Reference Library(No Merge)) 这个选项
d中取消上述的选项
是否这样?
发表于 2011-12-14 08:47:59 | 显示全部楼层
完全正确,   icc到 icfb merge layout就是这个flow,
icc的选项里面加一个  -skip_ref_libXXX   ,  write_stream_option
GMT+8, 2025-12-29 04:47 , Processed in 0.018942 second(s), 6 queries , Gzip On, Redis On.
