This warning (NRDB-733) indicates this pin does not have a physical shape defined properly in the LEF.
The possible causes are:
1. The pin does not have a RECT or POLY statement in the LEF to define its geometry.
2. Another reason is the pin may be defined as USE POWER or GROUND.
